I have a Jenn Air cooktop JED8430ADB which has sudenly stopped working (heating). What's weird the downdraft fan works & the knob to turn on the burners light up but not the burners. I checked the fuses in the electric panel & they seem to be fine. Unit is keept in excellent condition & never had any problems with it. Any suggestions would be appreciated?
SOURCE: downdraft vent on jenn air cooktop
Hello
Just get a dryer vent tube the flexible ones and some aluminum tape and that will do it, I had the same problem and thats how the gas company told me to do it and it works excelent.
Eddie Rentas
Tupper Lake NY
SOURCE: Our downdraft fan switch broke
There is no fuse on the unit. I suspect your house circuit is blown. If not, then a wire may have burnt off. Hope this helps!
SOURCE: Jenn-Air Cooktop replacement needed
You can get a new cooktop surface from Maytag/Jennair for $229. It is a pain however to replace it. Where is the crack in your cooktop and does that crack pass directly through a heating element? If not, then you may be able to repair it. I broke the corner off mine, and then dropped the piece (now 5 pieces). I was able to bond them back together and you really can't tell it was ever broken. But, it takes some work.
SOURCE: problem w/ plastic knobs on JennAir electric downdraft cooktop
NO METAL KNOB FOR THAT MODEL COZ IF USE METAL EVERY TIME U USE IS HOT THATS WHY DESIGN FOR PLASTIC,MUCH BETTER TO U REMOVE THE KNOBS AFTER U TUNN ON THE HOBS TO LESS MELT THEN RETURN IT IF U TUNR IT OR ADJUST.
