NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router Logo
Posted on Jan 26, 2010
Netgear dualband wndr3300 - Why can I only connect to one band
Neatgear wndr3300 - Why can I only connect to one of the dual bands? I can typically connect to 2.4 but could not connect today and had to connect on the other band? What is a dual band and why can I connect on one band and not the other?
Anonymous
Level 1:
New Friend:
  • Contributor 37 Answers
  • Posted on Mar 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
37
Questions
Helped
11055
Points
40
Dual band means it is working on both 2.4Ghz and 5Ghz frequency. If your computer can connect on both frequency that only means that the wireless adapter in your computer is also dual band.
How do i turn off mac filtering on my netgear wndr3300 rangemax dual band router through my computer/
MAC address filtering is configured in the wireless settings.
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
I want to set up my wifi dvd player to one of the wifi connections and leave the other for my lap top. don't know how to use both of the wifi connections.
This is NOT a DVD player. The Netgear RangeMax Dual Band Wireless-N Router WNDR3300 features a rather misleading name. The router doesn't support true dual-band wireless-N, nor does it offer very good range. It's a basic router with two separate access points (AP), one of which supports Wireless-N and can operate in either 2.4GHz or 5GHz frequencies--similar to the D-Link DGL-4500--while the other is a regular 802.11G 2.4GHz-only AP. The result is that when in dual-band mode the router is able to offer Wireless-N only in the 5Ghz frequency, while the 2.4Ghz frequency is maxed out at the 802.11G speed. Still, if you have a growing stable of 5Ghz-based devices and want a router that supports both frequencies, the WNDR3300 is the cheapest router on the market (at about $100) that will suit your needs.
While its max throughput is relatively low, the router offered very consistent and considerably high throughput speeds on both our mixed-mode and long-range throughput tests. Unfortunately, its range is possibly the shortest among Wireless-N routers. If range is not important to you and your network primarily consists of 5GHz-based clients, the WNDR330 is a good bet. Otherwise, for the same price, we'd recommend the 2.4GHz-only Linksys WRT310N; or you can pay $50 more for the true dual-band Linksys WRT610n.
1helpful
How do I connect my Arris TM502G to my Netgear WNDR3300? I go through the setup and it says error cannot connect to the Internet. I need help.
Please let me know who is your internet service provider(ISP)
then i can give you instruction how to setup router
Happy to help
Thanks for using Fixya
I have two range max dual band wireless-N router wndr3300's. I want to set one of them up to act as a repeater. How do I do this
HI,
Visit the below link to know about the required settings to configure repeating between WNDR3300:
http://kb.netgear.com/app/answers/detail/a_id/2745
Let me know if you need any further help.
Regards
Anand
NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
