HP Compaq Presario CQ50-110US Laptop Logo
Posted on Jan 26, 2010
Compaq Presario cq50-110us LCD replacement
Can anyone direct me to a guide (with pictures) that describes the process for removing and re-fitting the LCD unit on a Compaq Presario cq50-110us notebook? I have bought a replacement unit already.
I need to know what tools are needed and if this job should be attempted myself or if I should pay for it to be done at a computer shop.
Anonymous
Level 1:
  • Contributor 31 Answers
  • Posted on Jan 26, 2010
Anonymous
Contributor
Level 1:
Answers
31
Questions
0
Helped
7239
Points
76
Check the video software of your laptop maybe its adjust
How to replace the lcd on a compaq presario CQ60-615dx
Here is a website with step-by-step picture instructions on how to replace the lcd on your particular model of laptop.
Thanks, and have a great day!
2answers
LCD Replacement for Compaq Presario CQ40
i would recommend you
www.laptopscreen.com
good warranty fast shipping good price too
1helpful
My hp compaq Presario V6500 has been damaged and a computer dude in Bathurst NSW said we need a bulb replaced in the screen as it won't light up. Computer functions via TV. R there any local repairers for...
The monitor screen on your laptop is an LCD screen.
An LCD screen cannot produce enough light by itself. It needs an additional light source.
The additional light source is a Backlight.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes and businesses, but on a MUCH smaller scale.
LCD screens are a composite of layers. The layers are held together by a metal frame, much like a picture frame.
The Backlight is usually located on one side, accessed after removing one side of the metal frame.
As stated, a Backlight is a very small type of Fluorescent lamp, (Tube)
Very fragile, easily breakable, and not usually approached by one who has very little, or no experience in replacing.
More common the entire LCD screen is replaced, which includes the Backlight already installed.
A laptop also needs an Inverter to provide power, both for the LCD screen, and the Backlight.
90 percent of the time the fault is the Inverter.
I repeat, 90 percent of the time the fault is a bad Inverter.
An Inverter is cheaper than an LCD screen, and MUCH easier to replace than a Backlight.
Allow me to show you replacing an Inverter on an HP Pavilion dv6000 series laptop.
Granted, it isn't an HP Compaq Presario V6500 series, but the principles still apply the same,
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
I can also provide a free link, to the Service Manual for an HP Compaq Presario V6500 laptop, direct from HP Support,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3369429&
In the list click on;
Compaq Presario V6500, V6600, and V6700 Notebook PCs-Maintenance and Service Guide
This is a PDF file.
Allow up to 30 seconds to see the first page, and an additional time may be needed to fully download.
In the Bookmarks menu on the left click on the + sign next to;
1) Removal and replacement procedures
2) Component and replacement procedures
3) Display assembly
And/or go directly to Page 61 to view the Inverter location.
One example of an Inverter for an HP Compaq Presario V6500,
http://www.sparepartswarehouse.com/Compaq,Presario,V6500,Laptop,Inverters.aspx
Granted this is not what you asked for.
My premise is to teach, and hopefully save people money.
If you have additional questions please state in a Comment.
Regards,
joecoolvette
My Presario 300 has two broken hinges
Yes they can. You can buy new, or look on Ebay to see if any are available.
You have to remove the LCD Screen Bezel, LED Cover, (Switch Cover), and the Keyboard to access both hinges.
Sound like I'm typing a foreign language? Let me show you a guide to replacing those hinges, complete with photos, so that you may better understand,
This is a PDF file download for a Compaq Presario 305. After you click on the link, give it time to fully download before looking through it.
Here is the direct link,
http://www.elhvb.com/mobokive/edwin/laptops/Compaq/Compaq%20Presario/Presario%20305.pdf
If that doesn't work for you, here is the page it came from,
http://www.elhvb.com/mobokive/edwin/laptops/Compaq/Compaq%20Presario/index.html
It's in the right column. -> Presario 305.pdf
Start with Page 18, Preparing For Disassembly
Read and view Pages 24, 25, and 26. These pages show you the three connectors that must be disconnected, Display Panel cable, Inverter cable, and Audio cable.
(Pay special attention to how a ZIF connector comes apart. It's real easy to do, believe me. Page 23 shows you. You'll see that the ZIF connector is made up of two parts. The main connector body, and cable guide. The guide is shown in an up position in the illustration. It is down next to the main body of the connector, when you start. The guide does not come out all the way. You merely lift it up with your fingernails to the position shown, and the cable slides out. To replace, insert the cable in the correct orientation, then push the guide down against the main body)
Removing the keyboard is on Page 37. Removing the Switch Cover is on Page 40.
Removing the Display Panel is on Page 42.
Don't let this task seem that daunting. You CAN do it! I advise using a clean egg carton for the various screws. Label each egg holder for where the various screws come from. (Sounds pretty techy, huh? lol! That's what I use!)
5helpful
2answers
Compaq Presario V4000 (v4118AP) right hinge broken
I had the same problem, they are very easy to fix, I did a search earliar and found some on the link below.
http://www.pchub.com/uph/laptop/291-29919-6327/Compaq-Presario-V4000-Series-Hinge.html
You do not need to dismantle to base, you have some star screws under the battary and one either side that loosens the small panel near the screen (where the power button is). The screen cover has screws under the plastic covers then just unclips, be gentle. after that it is self evident
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
