New SHE4AM16UC, professionally installed eight months ago. Worked fine with light usage until now. Dishwasher starts normally but stops and signals "clean" after less than five minutes on any cycle. One inch of water in bottom that (I think) drains when a new cycle starts. Soap tablets are not ejected from compartment. Bosch authorized repairman says he now has two client dishwashers with identical symptoms and is asking Bosch support for ideas (he's changed pump, control unit, and float switches in the other dishwasher). Ideas?
For my Bosch Ascenta Dishwasher SHE3AR56UC/16 solution was to replace Control Panel (i.e. Control Board) located in the top of the door with Bosch Part No. 00705306 (AP5306751 at ApplianceParts Pro.com).
http://www.appliancepartspros.com/bosch-control-unit-705306-ap5306751.html
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
I
have an older dishwasher also and recently my wife also complained
about it not cleaning right... so me being the man I am tried in vain
to clean the things... Bought new spray arms online and installed
them in minutes...now the thing works like new... However I have also
found that if the heating element goes bad then that also can mess
things up bad... So I would buy new spray arms, and also check out
the heating element to make sure it is working... Here is a tip that
will help you with the online buying...
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
bad heating element causes many problems in
dishwashers...
Dishwasher Problems The Heating
Element not Working
Dishwasher
Maintenance
heatman101
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
k;kjguit
