It is a front loading washing machine. All parts of the washing cycles work fine, except the spin cycle. It spins, but slowly, not fast enough to be effective as a spin cycle. Replacing the motor and the circuit board had no effect, the problem was exactly the same. The tub spins freely. The door latch works. It was an illuminated light when the door is locked and cannot be opened, and it won't open as long as the light is on. When the spin cycle should be on, the light is illuminated and the door won't open. After you stop the cycle or turn the machine off, you must wait approx 60 seconds before you hear a "click" and the door will open.
Any ideas on why the spin cycle won't get up to speed?
Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Problems
with a washing machine not spinning or not draining are often inter
related..
If you are having a problem with your top load
washer then check out this tip...
Washing
Machine
does not Pump or Spin
If you are having problems with your
front load washing machine then checkout this tip...
Front
Load Washing
machine not draining and or not spinning
heatman101
