Casio Privia PX-800: When using the sustain pedal, sometimes the keyboard will lose power for a split second. The display flashes off and on real quick, and you lose all sound. Only for a split second, but enouph to screw up your playing. What could be the cause of this?
Check if the cble frm the pedal MIGHT be flexing or pulling on the keyboard case when you use it. Such movement COULD vibrate the power connector causing your problem.
Make sure you have the right power supply for the unit as one with too large a hole for the power pin would be intermittent like this.
