Sometimes tv wont turn on for hours at a time,the cable box and everything else turns on but not the tv, not until we hear a clicking sound will it turn on....panasonic TH-50PX75U
Try unplugging the TV cable from the mains and leave it off for a few hours. The longer you leave it disconnected from the mains ( i recommend overnight) the better the chance it will reset the TV.
When you switch the TV on, try pressing the SOURCE button until you get a picture from the cable/sat box or whatever connected to the TV.
If this fails you may have a problem with the power circuit board. This will cost approx £150 for parts and labour from you local TV repair man.
The faint click sound is the protection circuit that keeps turning off the TV.
This happens when an internal fault is detected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
You now have a defective lamp ballast board. It sometimes is the root cause of lamp failures in these sets. The problem here is that Toshiba does not sell the ballast board independently from the larger, more expensive light engine assy. Call Best Buy back and get a servicer out there. He may have to take the ballast board out of your TV and send it out for rebuilding.
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Also
or dvd connected.
1The
protection circuit.
Common faults
Check also
Unfortunately, we have the same problem. We hear popping and our sound goes lower. It is not the cable box for us, it's definitely the TV; however, it happens, on our set, after its been on for a few minutes and then goes away after half an hour or so -- however, this evening its been happening for the past hour and the TV has been on for the evening.
