You have a fuel issue and is most likely a blockage in the carb.
My ef2400ishc did the exact same thing. I opened her up and found the rubber hold down ******** the aluminum heat sink had broken. the heat sink was rubbing and i believe shorting a nearby cable at the cable terminal near the end. Tape up the terminal connections and I jimmied a rubber hold down strap out of 5 or six zip ties looped like a chain. So far so good!
