How do i change the ink cartridges on the HP Officejet 5510 All-in-one thermal printer? Where are the ink cartridges located?How do i change the ink cartridges on the HP Officejet 5510 All-in-one thermal printer? Where are the ink cartridges located?
AnonymousFeb 26, 2008
Where is the ink cartridge on the HP5510 all in one?Where is the ink cartridge on the HP5510 all in one?
AnonymousFeb 29, 2008
location of the ink cartridge on the 5510location of the ink cartridge on the 5510
AnonymousMar 04, 2008
where is the ink cartridge located?where is the ink cartridge located?
AnonymousMar 09, 2008
need assistance in locating and changing ink carthridgeneed assistance in locating and changing ink carthridge
I can't find the way in to change the ink cartridge on HP 5510 officejet all-in-one - help!I can't find the way in to change the ink cartridge on HP 5510 officejet all-in-one - help!
You can't post conmments that contain an email address.
THERMAL there is no ink
it uses special paper that when HEATED it changes color
if there is a copy quality problem, the paper might be too old, installed upside down or the printhead is gone bad.
IF however you mean the officejet 5510.....
that is an ink printer
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&lang=en&docname=c00033420&rule=29833&product=311255&dlc=en&
Hi I suppose its would not be advisable for you to remove the sensor unless you know about the printer status. Please give it to a service provider who can diagnose and replace the sensor, Mostly sensors are basically for paper trays to pick up and print the printouts
this should work for all 5500 hp printers
i hope this helps you out
richard from chicago
i just noticed you have the wrong cartage
you need hp 57 color
that will make all the difference :-)
HP Officejet 5500 series
All-in-One modelBlack cartridge Color cartridge
HP Officejet 5505
HP 56
HP 57
HP Officejet 5508
HP 56
HP 57
HP Officejet 5515
HP 56
HP 57
HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v
HP 56
HP 57
HP Officejet 5600 series
Replacing the print cartridges
Turn on the HP Officejet, and lift open the print-carriage access door.
The print carriage will move into the access area.
Figure 1: Opening the print-carriage access door
After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
Figure 2: Removing the print cartridgeNOTE:
It is normal to see ink buildup in the print cartridge slots.
Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
CAUTION:
Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
Figure 3: Removing the plastic tape
Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
CAUTION:
Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
Figure 4: Inserting the print cartridge
Close the print-carriage access door.
Aligning the print cartridges
The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
When the message displays, press OK .
The HP Officejet will print an alignment page.
Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
Press OK .
The HP Officejet will align the print cartridges and display Alignment Complete .
Hi, I can help you. The ink is behind the print-carraige access door. Here is a link to the printer manual, go to page 63. But by all means download it and save it to your desktop. That is a good printer, but pretty complicated sometimes. Good luck.
