Look for popped Capacitors. These are the tiny cans that are on the circuit board. They usually buldge out on the top and leak white paste. Good luck and i hope this helps.
as your sub is only rated to 400w rms simply connect the sub to either a or b channel outputs you may wish to use an rca splitter before the amp to feed both left and right audio channels into a single channel on the amp. WARNING connecting both channels on the amp to the sub will overload the sub and possibly blow it up so i highly recommend not doing so.
almost any amplifier amp would push a 400 watt sub. try to stick with a name brand, and steer away from no name brands like boss, jensen, etc.you will only need a 2 channel amp to run your sub.you will need a second amp to run your 6x9'sor you could get a 5 channel amp, and run all your speakers, and the 5th channel for your sub
you can run your amp at 1 ohm you would need to to have the right ohm subwoofer wired in parralle to get 1 ohm at amp ...... the put a 12 volt fan in the area to keep the amp cool so it doesnt over heat if you plane to Audiobahn A2X400HQ 2 Ch Amp 1600w x 1 @ 1ohm - 800w x 1 @ 2ohm 600w x 2 @ 1ohm - 400w x 2 @ 2ohm 2-Channel High Current Amplifier -- Ideal for use with all Audiobahn Rack Mount Products
Rockford fosgate usually work best with 2 ohm speakers. Depending on the resistance of your speakers, will then give you best connection. Check the resistance for the subwoofers. If the subwoofers are two ohm then connect them directly right and left. But if they are 4 ohm connect them parrallel (positive to postive, negative to negative and bridge the amp.) Good Luck, please rate.
