just shut your door first,before setting the remote to lock your car as doing that needs your door closed and switch your interior light to working only when your door is open. your door and that light is part of your alarm.
Probably you have a weak battery in your remote transmitter. When the garage door is closed it requires a stronger signal. Open the remote and replace the battery.
Have you changed the battery recently? My remote has a bad habot of slightly misaligning the cel switches if I don't close it exactly right. For my Chrysler van the sliding door switch is affected that way. All else works, though. I end up opening the remote again and ensuring it snaps shut all the way around with just one compression. If an edge doesn't close it's try again. The good news is it's virtually always the remote at issue and nothing expensive in the vehicle.
Make sure you have no soot build up on your ignitor. It will conduct elect so you can hear a buzz instead of a clear spark. Without a clean spark it wont fire and for safty it shuts down to keep gas from building up in the cabnit.
do not lock doors with facory switch it is setting the factory alarm must shops dont get the factory disarm alarm wire to shut it off.this will always happen use the remote with the remote starter to lock and unlock doors and it should be fine
