Re: Black Max 6250 generator worked good for 10 hrs and...
Hi there:
Remove the back cover and look for damaged brushes or electronic parts, I'm assuming you have some electric-mechanical skills. otherwise you better take it to a service shop
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
You have excessive arching on the rotor slip rings by the sound of it, if you clean them and it works well then 3 hours later same problem? What is the conditon of the brushes? Also I trust youa r enot cleaning polishing them with sanpaper etc, they have a very fine finish and should be polished with a super fine grit paper or stone, pref while turning the engine. Any scratches won't work
I doubt its anything to do with brushes unless power system has shutdown incorporated, could ignition coil breaking down when it gets really hot or similar check the oil level cut out switch
Heat is the enemy of solid state devices. Please, check that the heat syncs are properly installed and that there is no obstruction to good air circulation around the circuit boards and around the generator. Any heat shields removed to replace the circuit boards need to be reinstalled in the original configuration.
you must dislocate the handle and it's base ...you will find the magnetos in the FLY-WHEEL area.trace it's wireing till you find a cut-off black wire...and reconnect it...
PS. it might be disconnected and not cut...and that way it will be harder to trace..
