Hi. I bought a refurbished Nortel audioconference phone. I can hear callers but callers can't hear me. Do you know why? Thanks.
SOURCE: Changing MAIN voicemail announcement
I am not a phone installer and we have another vendors' phone system here at our work.
It can be *extremely* difficult setting up these phone systems, even with a manual.
Here is one such link that might help:
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Here is another forum that has lots of friendly folks that might be able to help
http://www.sundance-communications.com/forum/ultimatebb.php?/ubb/forum/f/8.html
You will get an answer much sooner on there than here probably.
Mike
SOURCE: Callers say they cannot hear me
Yes it very well could be your phone lines and not the system. Call your provider and tell them you have low speech path on your lines. They will troublshoot it.
SOURCE: Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
SOURCE: Need Caller ID displayed on Nortel StarTalk Flash/M7310
A question: -> does your phone ring? -> what software are you running on the system? If you know this will help a little in giving you more information. There is a Feature that you can dial if your phone rings... when there is a call coming in, dial FEATURE 8 1 1 You can even make this a button rather than dialing this feature code everytime: -> Feature * 3 -> press the button that you want to program -> dial Feature 8 1 1
SOURCE: Program a new Nortel m7310 phone with an existing extension
If the extension was a swap of the old M7310 with a new(ish) M7310 no additional programming should be necessary. However if the phone was replaced with another type of nortel set(M7208, M7324,T7313 etc.) then the phone will default to its base features. To re-program the feature keys press feature *3, the button you wish to program, and the feature code for that button
