Taylor 7506 Precision Tech Lithium Battery Electronic Glass/Chrome Scale Logo
Posted on Jan 25, 2010
How can i replace battery in Taylor lithium scale model 7506
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 15, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
3950
Points
Turn it over and open the battery compartment. CR2032 battery
Escale not reeding properly
Had same problem, but then I put it on the hard ground
When you get onto the scale (Taylor Lithium 7506), the numbers just keep cycling and never stop. We tried changing the battery, even though the scale is less than three months old, but it still does the...
Turn it over - take out battery and check with multimeter to ensure it is still workable - let sit for 10 to 15 seconds - replace battery - set it on level surface and step on and back off. Step on it again and it should now work.
3helpful
My scale showed Lo, no reading, then I replaced battery, now shows nothing, dead. What do I do next?
The Instruction Book for your scale can be found here:
http://www.taylorusa.com/media/IBs/7506_ib.pdf
Sounds like no power. Check for correct battery replacement; may need to verify that your replacement batteyr is still good.
Battery Replacement
1. Use 3 volt CR2032 lithium battery (as installed).
2. Open the battery compartment on the bottom of the scale.
3. Remove the old battery from the compartment.
4. Place the new battery with the "+" sign up into the battery compartment.
5. Replace the battery compartment cover.
1helpful
7506 Glass digital lithium scale battery replacement. I need the battery no. please...
The lithium battery is a 3-Volt CR2032. The manual for the scale is available here: http://www.taylorusa.com/media/IBs/7506_ib.pdf . Additional information and a link to the manual is available here: http://www.taylorusa.com/weight-management/glass-electronic-scales/glass-lithium-electronic-scale.html .
I hope this helps.
For taylor scale model 7075. How do I fix error code 6aee
I know what is this error. This is BATTery low. New battery last only 2 month, I've seen a problem with the kick feature to power-on the scale, those pressure buttons might get stuck and leak current and kill the battery.
ERROR message
This link allows you to troubleshoot directly with the company...I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Top Taylor Health & Beauty Experts
ZJ Limited
ZJ Limited
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
