How do you zero out a health o meter weight tracking scale?
How do you zero out a health o meter weight tracking scale.. One of the kids stepped on mine, and recorded a weight and now I don't no how to clear out the number?
Re: How do you zero out a health o meter weight tracking...
After stepping on the scale to Activate your number (1-4), hold it down and it will say "reset" or (something to that effect), then Yes, or tap it once and it will say "no". If you want to reset, when it says "Yes", continue to hold it down, and it will then reset to zero.
E. If the device is showing the error "E" on the message screen, check to make sure that you are not moving while calculating the weight. ... If after this the error message hasn't gone away, there may be bad connection on your scale.
Stepping on the scale before the "000.0" causes this error message to appear. If "E" appears, step off the scale and repeat initial RESTART by tapping on the center of the scale. Wait for the scale to indicate 00.0 or something like that THEN step on.
You do not reset the scale. It only saves the last recorded weight of the user. So, if you weighed yesterday, it will put your recorded weight in memory. The next time you select your user number and step on the scale, it will compute the difference from your previous record and save your current weight.
