Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
Posted on Feb 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panafax uf585 Our company changed names, and our outgoing fax's still have our old name on them for the header info, how do I go in and change this?
A
Anonymous
Code error 021...How can I fixed?
A
Anonymous
CheckitRight
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Panasonic Master 1,363 Answers
  • Posted on Feb 15, 2008
CheckitRight
Panasonic Master
Level 3:
Renaissance:
Answers
1363
Questions
Helped
646817
Points
2795
How do I change the company header on this fax machine?
with function key go to entry mode and own number set .change name and number
3helpful
I need to change the name on outgoing faxes from my HP 6310 Officejet, but cannot find the information in the owner's manual. Can you help?
This "Fax header" information can be changed on the OfficeJet 6310 control panel:
1) Press the <Setup> button
2) Press 4, then press 1
3) Enter your personal or company name
4) Enter your fax number
You may have to use the numeric keypad to enter letters. The number of presses of the key changes the letter.
I hope this helps!
I want to change the name (My caller ID)when I fax how can I do that It show up as Holy Dreams that name of our former company. I want it to show as our new company. How do I do that
I believe you wish to change the "Station ID" on your MFC-240C. This setting will print out your company name and other header info on your faxes:
1) Press the <Menu> key
2) Press <Up> or <Down> Navigate to "Initial Setup"
3) Press <OK>
4) Note: Your station ID is already set, therefore the machine will prompt you to choose: (1) change, or (2) exit without changing - choose (1) to change
5) Enter your fax number, then press <OK>
6) Enter your company name using the dial pad keys. This may take a little practice. Press the dial pad key the correct number of times to produce your desired letter. Use your (>) right navigation key to advance to the next space. If you entered a letter incorrectly and want to change it, press the left navigation key to move the cursor under the incorrect letter.
7) Press <OK> when finished
8) Press <Stop/Exit> to resume normal operation
There! You should have it. I hope this helps!
Brother MFC 240C Station ID
3helpful
Need to change the outgoing name and address on a Canon fax G3 L2
To change outgoing name and address, use the following procedure:
1 Press Function.
2 Press Data Registration.
3 Press OK twice
4 Use UP Down arrows to select Unit Telephone #
5 Press OK
6 Use the numeric buttons to enter your fax/telephone number (max. 20 digits,including spaces).
• To enter a space, press Function
then Space. Spaces are optional
but make the number easier to
read.
• To enter a plus sign (+) before the
number, press #.
• If you make a mistake, press C and
re-enter the number.
7Press OK twice.
8 Use the numeric buttons to enter your name or company name (max. 24 characters, including spaces).
9 Press OK.
10 Press Stop to return to standby mode.
Below is a link to your L=220 User Guide:
Canon L220 User Guide
I hope you find this answered your question. Best of luck to you!
Greg
2helpful
How can I remove the sending fax number on my transmissions on HP
Check the HP Officejet Pro L7300/L7500/ L7600/L7700 All-in-One series
User Guide
(page 83):
"Configure the fax header:
The fax header prints your name and fax number on the top of every fax you send. HP
recommends that you set up the fax header by using the software that you installed with the device. You can also set up the fax header from the control panel, as described here.
NOTE: In some countries/regions, the fax header information is a legal
requirement.
To set or change the fax header
1. Press Setup.
2. Press Basic Fax Setup, and then press Fax Header.
3. Enter your personal or company name using the numeric keypad, and then press OK.
4. Enter your fax number by using the numeric keypad, and then press OK.
To set or change the fax header via the embedded Web server
▲ Select the Settings tab, select Fax from the left pane, select the Basic sub-tab,
and then enter the Fax Header Name and Fax Number. Click the Apply button."
Panafax uf-780 how do i change the outbound "name" on the top
Press
function
71
set
clear the number
enter your fax number
set
set
clear the namr
type in name
set
stop
type in name
1helpful
Info Code 054 - Printer Error - cannot be found in manual
sorry to tell you its the lsu laser unit in the machine the only way to fix it is to replace the part
2helpful
2answers
Incorrect Fax Number showing on sent Faxes
the solution given is correct. happy faxing OMNIPRESENT
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
