Samsung HP-R5072 50 in. Plasma HDTV Logo
Anonymous Posted on Jan 25, 2010
Samsung plasma hp s5053x/xaa blank screen
Samsung plasma hp s5053x/xaa "2006" powers on blue ring is solid no blinking, clicks once as it sound like its powering up, makes a digital sounding melody, and then no picture? any idea where to start? dont see any bad caps?havent taken anything apart yet other than to remove the back cover....
wisiny.com
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Samsung Master 848 Answers
  • Posted on Feb 02, 2015
wisiny.com
Samsung Master
Level 3:
Renaissance:
Answers
848
Questions
0
Helped
453983
Points
4753
Samsung plasma hp s5053x/xaa blank screen? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
IP 45130A Samsung BN44 00127F Power Supply Backlight Inverter
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Feb 10, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
4979
Points
9
Sounds like P-LOGIC MAIN
Samsung plasma tv model HP-T5054 MODEL CODE HP-T5054X/XXA CA5OC9 Manfactured June 2007 Mexico
Plasma is old technology and it is 16 years old and made in Mexico, the worst place for quality control. It is time for a new one, or at least an upgrade. Or you can get a board kit and take a chance on fixing it.
Samsung HPT5054X/XAA Service Manual
ManualsLib https://www.manualslib.com > ... > HPT5054X/XAA
View and Download Samsung HPT5054X/XAA service manual online. Plasma Display TV. HPT5054X/XAA plasma tv pdf manual download. Also for: Hpt4254x/xaa, ...
Boards for it.
https://www.google.com/search?q=Samsung+plasma+tv+model+HP-T5054+board+kit
Televisor Samsung Model: HP -S5053 Model Code: HP S5053X/XAA Type: CD50P7 AL ENCENDER SE ESCUCHA PERO NO SE VE. QUE PODRA SER LA TARJETA DE VIDEO?
If you wish to get some details; check the site linked here. Pull up older posts.
https://elektrotricks.blogspot.com/
https://electronicshelponline.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter.
Samsung tv hp-s5050 model code hp-s5053x/xaa remote turns tv off an on but no picture no sound red light flashing inside of tv how munch will this cost talking to you i do not want a member ship
Remote possibility that a fuse inside has blown. Try TV's on/off switch, not the remote. Try unplugging and wait awhile and plug in again. The odds are that your TV has died, RIP, sorry.
7helpful
My 50 inch Hitachi plasma 1080 tv has a blinking blue light and screen is blank when powered on.
my hatachi hd/1080 tv has a solid blue light on and it wont turn on i push the reset button on the bottom right and it still wont turn on
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
13helpful
6answers
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
1helpful
4answers
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
