Intel Celeron D 335, 2.8 GHz Processor Logo
Posted on Jan 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have pentinum4 intel(R) celeron processor 1.3 GHZ processor. I want to increase the speed of my processor without any hardware change. I have 40 GB HD & 512MB with windows XP RAM.plz help
Anonymous
Level 3:
  • Master 415 Answers
  • Posted on Jan 25, 2010
Anonymous
Master
Level 3:
Answers
415
Questions
0
Helped
125052
Points
1200
You cannot change the speed of your processor unless your processor supports overclocking. however your processor does not support that.
if your computer is running slow try upgrading the RAM to 1GB.
also check to see whether you have unwanted applications running in the background
1helpful
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
1helpful
I have been given a acer aspire L320 BUT THERE IS NOT A PROCESSOR IN IT. what i want to know is what processor fits.it
The Acer Aspire L320 can take 3 different processors
1. Intel Core 2 Duo
Dual Core chip with speeds from 1.8Ghz to 3.3 Ghz
2. Intel Celeron D
Dual Core chip with speeds from 1.6Ghz to 2.7Ghz
3. Intel Pentium 4
Single core chip with speeds from 1.3Ghz to 3.8Ghz
The Core 2 Duo 3.3 Ghz is the most expensive and Pentium 4 1.3 Ghz the cheapest.
Some more information is available on the Intel website, links are below:
http://www.intel.com/products/processor/core2duo/mobile/index.htm
http://www.intel.com/products/processor/pentium_dual-core/specs.htm
Hope this helps. Thanks for using Fixya.
Need apower supply and hard drive for my compaq presario 1103WM. how old is this unit
It must be up to 8 years old ish as it has XP installed.
17-inch flat screen CRT monitor NEW* Intel Celeron D Processor 3252.53 GHz, 533 MHz FSB, 256 KB L2 cache 256 MB DDR SDRAM CD-RW (48x32x48) 40 GB hard drive 9-in-1 memory card reader 10/100Base-T networking interfaceIntegrated graphics with 64 MB shared video memory *The new Celeron D processors are more efficient than the old Celeron processors. The New 325 D benchmarks faster than the old Celeron 2.7 GHz processor.
Almost any IDE hard drive will work, up to 540Gb and any reasonable power supply should be OK. Check ebay and also google for a power supply.
Hope that helps.
1helpful
Celeron 540 upgrade
Aspire 4315 Specifications Specifications
Part Number
Varies by specifications
Processor / Speed
Intel Celeron mobile processor 530/540/550 (1 MB L2 cache, 1.73/1.86/2 GHz, 533 MHz FSB), supporting Intel 64 architecture
if you have a 2 Ghz processor installed, you will have to replace the motherboard to go with a faster CPU.. which will be spendy..
Hope this helps
1helpful
Maximum MB or GB of graphic memory supported by Celeron d 325?
you can as high graphics card as you want as long as the is a PCI card.
hope this helps.
please rate good.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
1helpful
I have an eMachine T2240 with an Intel Celeron processor 2.20 GHz & 384 MB of RAM.  The only real complaint I have is that this machine runs slow - it is rather aged - and I tend to bump up against my...
Memory: Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot. You may purchase here.
This will give you the biggest speed increase.
CPU: I could not find specs for which cpus this motherboard supports. However, I had one of these same machines and succesffuly swapped out the celeron processor for a pentium 4 processor, 2.53 GHz. You should be safe finding a used processor on ebay that's a Pentium 4 2.2 GHz and it should work for you.
Thanks and please take a moment to rate as fixya.
2answers
Motherboard capable of running 533 fsb, running at 133
You would have to run the 533 FSB at times 5 or 6 to get 2.4GHZ.
And if you did you probably would not see any increase in speed
Just because a computer can do something does not mean it should
Internet surfing
yes its true. computer specs gives a big factor on internet connection. even though you have a fast speed broadband but your computer is low ed. it will lead to a low opening page like when your browsing with a high definition web page but your processor, memory and graphics coudnt cooperate well to the connection. thats what we called frame per seconds or fps.
cheers
CHARCOIS
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
