SOURCE: water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
SOURCE: GE front load washer, wbvh5200j1ww. no power.
the door can be manually unlocked by removing the bottom front panel, reach up and there is a pull tab on the lock mechanism. it is a crime that they do not post this online or in the manual, and let folks ruin their clothes.
power problem was a part called the "FILTER" it is where there power cord plugs into, something along the lines of part number 201. cost is $85 plus tax. service man has not seen one of these ever go before.
SOURCE: ge WCVH6800 front load washer.
Has this been solved? I have the same problem only I do not remember a power failure. But the other things are the same. <!-- from fixya rte -->
