Armitron Digital Sport #45/6853SIL Watch for Women Logo
Posted on Jan 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant set the time dont know button sequence - Armitron Digital Sport #45/6853SIL Watch for Women
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Jan 25, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1291927
Points
7081
You can obtain instructions by going to the Amitron web site (amitron.com), put the cursor over "support " and click on "instructions".
You will see a list of watch diagrams; choose the one that looks like yours and download the instructions.
  • Robert Wise
    Robert Wise Oct 22, 2017
    You probably meant "Armitron" - Amitron is a mfr of circuit boards. The Armitron website has no such links (any more); the website of parent company egluck is no help either.
1helpful
How to set the time on a Dakota one button watch
To set the time on a Dakota one button watch, you will need to follow the instructions in the user manual that came with the watch. If you do not have the user manual, you can try the following steps:
  1. Press and hold the button on the top right side of the watch: Press and hold the button until the time display appears.
  2. Set the time: Use the button to set the time. The specific sequence for setting the time will depend on the make and model of your watch.
  3. Exit the time setting mode: Once the time is set, you will need to exit the time setting mode. The specific steps for exiting the time setting mode will depend on the make and model of your watch.
It is important to note that the steps for setting the time on a Dakota one button watch may vary depending on the specific make and model of the watch. If you are unable to set the time using the steps above, it is recommended to refer to the user manual or contact Dakota customer support for assistance.
If you have a "his and hers" set of Dakota watches, the steps for setting the time on both watches should be the same. You can use the steps above to set the time on both watches.
1helpful
How to change from 12hour format to 24hour format on Casio watch la670w?
How to Set Casio Watch
specifically step 6 below for your answer
Setting Instructions for Electronic Watches
Casio electronic watches feature many different modes ranging from timekeeping to stopwatch. The M button controls the modes. Here is how to set time on a digital watch such as models 1632 and 1813:
  1. Press the M button to get into the Timekeeping mode.
  2. Select the seconds digits by holding the A button down until the seconds digits flash on the display.
  3. As the digits flash, press the C button, which will reset the seconds to 00. On some watches such as GW-500A, a stop/start button is used instead of a C button.
  4. Press the M button and change the selection in the order of seconds, hour, minutes, year, month and day. Proceed in that sequence to change information to the current time and date.
  5. As the sequence progress, digits flash when selected. Press the C or stop/start button, to increase a selected number or the B button to decrease it. Hold down either button to increase the speed of the selection change. All time and date functions are set this way.
  6. Press L when any digit is selected to switch between 12-hour and 24-hour formats.
I am unable to set time in watch Nako NA-823A
NAKO NA-823A Instructions
Turn Alarm on or off:
-Press the S and D buttons simultaneously.
Display Date:
-Press the D button.
Set time and date:
-Press the M button to switch modes in this sequence: stop watch>set alarm>set time>time.
-The S button will allow you to select seconds, minutes then hour, then day, month and weekday.
-Use the D button to clear seconds to zero, or move minutes and hours and date up by a single increment.
-Press and hold D for two seconds to move minutes and hours rapidly.
-Press and hold D while pressing and holding S moves through AM/PM and 24 hour (H) modes.
Use stopwatch:
-Press the M button until you arrive at the stopwatch.
-Press D to start and stop
-Press S to clear.
Display alarm time:
-Press the S button while time is displayed.
Jan 14, 2013 • Watches
My new analog american exchange watch has buttons and chronograph but wont or cant set, can someone help???
Watches are the best, I often take it as a gift. If you like online shopping, I can recommend to you my favorite, very good!
Jul 23, 2012 • Watches
1helpful
I don't know how to set the time on my watch back to regular time. It has four buttons, MODE, LIGHT, RESET, START STOP.
i dont know how to set the time on my watch .it has three buttons mode ,select and set help
I dont know how to change the time? I have no
to press left side upper button and right side butom button to set the time
4helpful
Sport tag h cant set time
The crown is lock that's why you cant pull the crown to set.The crown has a thread that lock, you must winding it clockwise to unthread it, so you can set the time..
Regards:
VOTIT
Dont forget to rate:
Stanley tape measure clock set time
On the bottom of the stanley clock you will see a little area that you put a coin in and twist,it will pop open to the battery and setting knobs.
Nov 03, 2008 • Watches
62helpful
13answers
Prospirit watch
in order to SHUT OFF THE ALARM:
go to the normal time setting, where nothing is flashing. then press and hold reset. then the time you want the alarm on shows up. in order to turn the alarm off press start...press start again to turn it on
May 15, 2008 • Watches
874helpful
11answers
Casio telememo 30 syncronising analogue and digital time
To set the analog time to match the digital time...
There are 4 buttons: top left=A, top right=B, lower left=C, lower right=D
Get the watch in timekeeping mode (where it shows the digital time or date)
Press C six (6) times
Hold down A until the current digital time begins to flash
Press D repeatedly to advance the analog time, one minute at a time.
If you need to advance the analog time at high speed, HOLD D DOWN.
To return to regular timekeeping mode, press C
Set the digital time so that it matches the analog time, since you can reset the seconds easily.
Top Armitron Watches Experts
Gene Lawson
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you an Armitron Watch Expert? Answer questions, earn points and help others
