Compaq Presario CQ60-220US PC Laptop Logo
Posted on Apr 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My compaq presario CQ60-220US won't turn on consistantly. Just no power to the on-off button. When I turn it off, it may or may not turn back on right away. Takes a day or so to finally respond to the on-off button. I can restart from the shutdown menu and I can put it to sleep but it won't come back on for a while if I close the case or manually turn it off. For no seeming rhyme nor reason, after many attempts it finally responds. Have run Kaspersky scans and check disk and all the maintanence programs that come with the system and they all seem ok. I use a pretty tight firewall and screens that come with Kaspersky.
goneforever.
Level 3:
Top Expert:
  • Compaq Master 14,531 Answers
  • Posted on Jun 27, 2017
goneforever.
Compaq Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263866
Points
66315
Wow, no tests down with battery out.
battery is the #1 failure in all laptop made. and fails many ways.
the firewalls does not source power, forget that.
If fact the HDD removed the power systems work perfectly.
tests,
run with no battery, IT MUST, if not the line power pack is TOASTED.
runs with battery only, no, yes? (if charged)
is this hard, no.
try to know batteries can short.
when they short they can overload any charger chip and can the PC.
Batteries are week techology
no battery ever lasts as long as the PC or any of its other parts.
the fail
some can fail in 6 months time.
why wait, run with no battery, heck some do for years.
after learning to hate batteries.
I have 2 and is only for travel every year, i test them before for my trip for proper run times.
only that works, in the world of batteries.
5 Related Answers
Joed911
JDTec
  • 4338 Answers
  • Posted on Oct 12, 2008
SOURCE: Compaq Presario 1700 PC Notebook Problem gives me a screen windows will not strat because file is corrupted or missing file is \windows\system32\config\system
Is this XP?
Do you have the XP cd or the recovery cd's. This needs to be fixed by performing a Windows repair.
missing or corrupt: \windows\system32\config\system"means that the OS,XP, is missing an essential file to run.
Or it could mean that your hard drive is failing. Is the hard drive noisey?
Leave me a comment,here
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
vleesje
Lorenzo Rack
  • 23 Answers
  • Posted on Feb 24, 2009
SOURCE: Laptop screen turns white
You can put your laptop on top of a icepack, cause your Graphics card is probably getting to hot. Thats why your screen turns white(probably only when gaming).
It is likely one of your fans is broken
Anonymous
  • Posted on Dec 24, 2009
SOURCE: Compaq Presario CQ60 touchpad problem.
The touchpad on my Compaq Presario CQ60 has stopped responding
Anonymous
  • 7 Answers
  • Posted on Feb 01, 2010
SOURCE: Compaq Presario V3500. Power up - 4 beeps and flash power light.
Try to ask the company what is happening
Anonymous
  • 393 Answers
  • Posted on Sep 14, 2010
SOURCE: My Compaq Presario CQ60 screen
You need to update the bios ... if u have programer open laptop u can see near the keyboard jack under tranpernt plastic u can see bios is 4*4 legs.. u can dowload bios bin or rom files u can update with programmer.. or u can check this way updating bios with USB even if there is no display .. for further information u can contact me @ [email protected] Thanks
Compaq Presario F700 Won't Turn On
Assuming the unit is plugged in, this could be an issue with the power supply, or an issue where the cord connects to the laptop. If the power connector on the back of the laptop is secure / doesn't feel loose or damaged, you may want to simply get a replacement power supply from a local electronics store. Be sure to take the make and model information of the laptop and the power supply with you to the store.
Why won't my Compaq Presario SR5712F cut on?
I would not recomend to CUT OFF. You can damage WINDOWS FILE STRUCTURE. Shutdown using menu or press once on power button.
Compaq presario won't boot caps lock blinking power button on
hi
maybe you have change the keyboard , it is failure
1helpful
Compaq Presario CQ60 won't turn on
If you already replaced the motherboard then try replacing the power cord. If you meant you replaced the cord already, the it might be your motherboard is bad.
3answers
Compaq Presario SR1123WM desktop won't turn on
Hello Kim.
When you press the power button, is there no life?
The PC may be set up for manual start instead of auto restart after power is restored.
Otherwise a surge may have blown the PSU.
Mine's not a Compaq but I'll research what the green light is.
Could be a modem....
My compaq 1725 computer moniter won't turn on when I press the power button. The actual desktop is on and seems fine but the monitor remains dark without even giving the orange light that it used to.
first check the power cable if its properly plugin, and check if ac to dc adaptor has a output power.
you can check it by using digital voltmeter or an analog multimeter, you can see the pin output in the back of the adaptor, it has positive and negative sign.
1helpful
2answers
HP Compaq Presario SR1820NX will not turn on
i worked for hp and compaq it is well known issue to reslove this issue
1#turn off the computer and uplug the power cable from the computer and then hold the power button for 20 second then turn on the computer and the momment you back to desktop screen
go to download driver from hp site and here is the web site http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-43507-1&lc=en&dlc=en&cc=ca&lang=en&os=228&product=1841849 and restart the computer .
Broken power button
They Have one for sale On ebay if you need..
Look here for your compaq presario X1000 power button bezel
http://cgi.ebay.com/APCL312M000-compaq-presario-X1000-power-button-bezel_W0QQitemZ230260679776QQihZ013QQcategoryZ60265QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hope it helps.....
http://www.wnycomputerpro.com
Power turns off itself then sometimes won't turn back on for sometime
have you tried your power options, you might have it set up wrong
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
