I am guessing you have the type of mixer that the head tilts back on. I would suggest loosening the bowl by tapping the handle to undo it. I usually use the palm of my hand to tap it. I am guessing the mixture is quite thick and loosening the bowl should allow the head to lift. I am also guessing that the pin that holds the head to the body and acts as the hinge has slipped out of place. It should be equal on both sides of the mixer. If it isn't, knock it back into position then tighten up the screw under the base that holds it in position.
