2005 TN'G Verona 150 Logo
Posted on Jan 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My wife has a 150cc TnGo verona scooter. It sat
My wife has a 150cc TnGo verona scooter. It sat for a bit, i tried to start it, it idled rough and died, kept trying and it would idle a little longer but anytime you touch the gas it dies. I syphoned out the gas tank and got it idling for a bit with the same results as before, cant get it to run right. The scooter only has 750 miles on it, have to say the thing has been nothing but a pain since we bought it...been through 4 batteries since we got it.
Anonymous
Level 2:
  • Expert 280 Answers
  • Posted on Jan 25, 2010
Anonymous
Expert
Level 2:
Answers
280
Questions
0
Helped
118871
Points
811
You have enough 2 stroke in the fuel? 50:1 ratio oil:fuel or more... it is a cheap engine needs extra lubrication..
Is the spark plug clean? --- Is the HT lead connector to the sparkplug fine or has it come loose? --- Check the air filter - it could be wet or dirty or clogged - replace it if it has gotten wet or is dirty, on such a new bike it should look white as the driven snow... --- spray some carb cleaner down the intake while cranking the engine, and rev it up while spraying the cleaner in there, maybe you have some gunk in the carb messing up the jetting. --- Adjust the Idle screw to increase the idle (but not so high that the bike is tugging to ride off) --- Check through that lot and tell me how you get on.
Have no spark to plug found a 2 wire clip with the same colors at the battery area that is not connected to anything. dont know where to connect trouble finding manuals or video
My scooter has no spark how to fix. gy6 chinese ... - YouTube
? 2:29
https://www.youtube.com/watch?v=UU4S0Ov9q4c
Aug 24, 2012 - Uploaded by Rolling Wrench
Purchase our "NO SPARK KIT" click the link below: ... Myscooter has no spark how to fix. gy6 chinese scooter 139qmb qmb139 50cc 150cc .... i have a 2003 panterra fusion scooter with a 49cc motor,i just purchased a new cdi box,new coil wire and a new stator and ... Put gas in it tried it again nothing.Missing: rto
RTO 150cc scooter no spark Questions & Answers - Fixya
www.fixya.com/tags/150cc_scooter_no_spark/browse/rto
Ask your RTO 150cc scooter no spark questions. Get free help, advice & support from top RTO experts. ... no spark. Ad. Question about Gas Motor Scooter 150cc.
Manual for 2014 taotao powermax 150cc scooter
Try these links:
Scooters TAOTAO USA INC
Mar 03, 2015 • Motorcycles
Scooter 150cc
check trade me, ebay and local store
When i compare my scooter with a 150cc scooter i found out that my acceleration is not good but only in the start any ideas?
Your scooter has a smaller engine than the 150cc scooter perhaps?
Seriously, without proper details, how can anyone help with this?
3helpful
Issue with my 2008 Adly Thunder Bike 150cc
People this is a scooter. The problem is that your idle screw on the Carb needs adjustment. The idle screw can be adjusted with a Philips screw driver. Follow your throttle cable to the carb. You'll see a screw that pushes a pulley down raising your rpms. This will lower your idle causing the rpms to drop and since your scooter transmission is propelled my higher RPMs the bike will stop thrusting you forward when you stop at red lights.
5helpful
2answers
Scooter Open Throttle (?)
Assuming the bike is not fuel injected, you either have a stuck slide, a throttle cable out of place such that it is lifting the slide or a really bad manifold air leak. Tighten the clamps holding the carb to the cylinder and the bolts holding the manifold to the cylinder. That should eliminate any air leaks. Inspect the throttle cable, especially at the ends where it connects. Remove the air filter and look into the center of the carb. Does the slide in the throat of the carb open and close properly? Below is a generic carburetor. Your carb will be similar.
2answers
1992 190e mercedes starts very hard
Check electronic temp censor take censor and boil water with a multi meter put it on continuity rage and test lead on censor continuity sould incrise as you dip min water is not the chage censor
Top TN'G Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a TN'G Expert? Answer questions, earn points and help others
