This has happened to me - however, the attachment pushed up and down on the spring with no trouble, and also turned.
The problem, it turned out, was the metal pin that sticks out - was sticking out TOO FAR. I put some WD-40 on the outside of the pin, and I used a small screwdriver and a hammer and gave it a few whacks so the pin moved back a bit. Once I did that, I could push up the attachment and unscrew it as normal.
When it's off, look at the pin and make sure it sticks out at least flush on one side if not protruding a little.
You do know you have to push it UP and turn it don't you?
OF COURSE!!! But is stuck, it doesn't go up or down...
