Yes; the water control switch is under the control panel it has a clear hose attached to it. the hose goes to a nipple on the tub. the weight of the water pressing down on the air in this hose turns off the water level switch. the hose has probably come loose from the tub or, the switch. also the switch could be bad. you can check the switch by blowing into the tub end and, listening for a soft click or. use a multimeter.
Sounds like the water valve solenoid is stuck open, or the water level switch also known as a pressure switch is bad. Turn the machine on as if you are filling it to do a wash and pull the plug from the wall. If the water continues to come in the machine with the plug out,you need to replace the water inlet valve where the hot and cold hoses hook up.
