Hold down the blue house button on the main menu until the toner levels and meter reading is displayed. Tap the toner remaining tab and the device will display your current toner level.https://business.sharpusa.com/portals/0/downloads/Manuals/MX-M1055-M1205/contents/01-072.htm
How do I monitor toner levels in my Sharp copier or MFP?
You can monitor the toner levels in your Sharp copier or MFP by pressing and holding down the COPY function key . Two pieces of information will then be displayed.
The Total Copy count on the device
and
The remaining toner levels. This will be shown in 25% increments. When you get down to 25% capacity check to see if you have spare toner on hand. If not, give us a call and we will promptly deliver.
Usualy what i did i use toner chip (100%) fix it to toner cartridge then insert to machine, check the amount if 100% then pull out the toner cartridge and replace old chip insert back to the machine, check it will be 75%.
E024 The developing assembly connector is disconnected/Disconnection of Toner sensor. 0000 The connection detection signal is absent continuously for 100 msec. Replace the developing assembly toner sensor. Connect the connector. Replace the DC controller PCB. 0001 Disconnection of the wire used for detecting the connection of the toner level sensor is found. When the disconnection of the wire used for detecting the connection of the toner level sensor has been detected for 7.5 min without interruption (12.5 min in the manual /envelop cassette feeding). When the disconnection of the wire used for detecting the connection of the toner level sensor has been detected for 12.5 min without interruption. -iR4570/3570/3530 When the disconnection of the wire used for detecting the connection of the toner level sensor has been detected for 7.5 min without interruption (12.5 min in the manual /envelop cassette feeding). -iR2870/2270/2230 When the disconnection of the wire used for detecting the connection of the toner level sensor has been detected for 12.5 min without interruption. Correct the cable. Replace the sensor.
TRY THIS:
Remove toner and check for broken parts on tube, check the connection of toner assy, reconect all connectors on dc controller pcb.
If you removed the toner assy before the error occcured check if all connectors are properly inserted.
On my APPLE the MAC OS driver depicts the toner levels when I check the printer status under the settings and preferences - printers icon - supply levels is an optional choice. I have not found a way to check the levels on an XP system.
