This problem maybe coming for n the generator it performs 3 function
1. controls electrical load / resistance to pedals
2. Charging system for the battery
3. Monitors unit when in use (stride) or when it is idle.
To test unit:
Remove cover disconnect red battery lead. then use a multi-meter set function to ohms set range that can read 50 ohms.
then disconnect generator lead from circuit board.
M3=brown , M4= blue, M5= violet, with the meter read between Brown and blue, blue and violet , brown and violet, each of these read should be between 26 and 27 ohms. If any of the reading s are high or low replace generator
If the engine cranks ("rrr-rrr-rrr") when you turn the key, then the problem isn't the starter or the battery.Plan to have at least one person sitting in the driver's seat and one or two persons pushing.Turn off all accessories (radio, wipers, lamps).Turn the key to the "on" position.Depress the clutch pedal with your foot.Put the transmission in first or second gear.Release the hand brake and the foot brake.Note that the people pushing need to get the car rolling as fast as they can. This works best down a hill or an incline.Release the clutch pedal while giving the engine a little gas with the gas pedal once the car is moving about as fast as you can run. The engine should start
