Not sure whether you have an extended drying option (4hr drying cycle) or the normal drying (30 minutes) cycle set up.
Check if you have selected the ECO or Fast cycle in which it does not generate enough heat to dry the dishes.
Otherwise can you hear the drying fan run towards the end of the wash cycle when the pumping has stopped?
if above answer is yes, then check if rinse aid is reservoir is not empty. If so, fill it and run dishwasher to see if it makes a difference. Also if you have hard water then rinse aid setting should be set at higher level
good luck. please post answers to above to help you diagnose the problem
Hi
make sure you are using rinse aid as this helps to evaporate the water at the end of the cycle in the drying stage. I know tablets have rinse aid built into the tablet but this can wash away on some wash cycles and do nothing so even if you are using tablets i reccommend still using rinse aid.
