I will suggest to check the wire harness from truck. try to take off the rubber grommet close to trunk hinges. then inspect if there is dammage wire but if you can;t find any fault with it, i suggest to disconnect one by one the connector from each door and and obseve the fuse and if the fault still existing check the central locking module for possible water ingress resulting to blown your fuse
