Hitachi 43FDX01B TV Logo
Posted on Jan 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment right but when I try to adjust left the vert. line stops about 1 1/2 inches to the right of center.
Chi Chu
Level 3:
  • Hitachi Master 8,457 Answers
  • Posted on Jan 24, 2010
Chi Chu
Hitachi Master
Level 3:
Answers
8457
Questions
0
Helped
2822478
Points
26282
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
My rear projection tv used to have green lines , now the color seems off and now its blue lines... How do i fix it. Color going out??
If colors are skewed or looks 3d it is a convergence problem.
Some sets when the convergence grid is called up will have green lines--green is fixed and red/blue adjusted to it.
To tell you how to fix I need to know brand and model number.
These are typical convergence problems--no two sets will look exactly the same.
2answers
Mitsubishi Rear Projection WS
5ebe434.jpg A projection television and a convergence control method thereof are provided. The projection television, which magnifies images displayed on cathode ray tubes (CRTs) for the colors red, green, and blue using lenses and projects the magnified images onto a screen, includes a convergence control apparatus capable of adjusting the convergence while an input image signal is displayed, the convergence control apparatus including: an image signal decoder which processes the input image signal to generate a data signal, horizontal and vertical synchronous signals, and a start signal indicating the start of either the horizontal or vertical synchronous signal; a convergence control unit which normally projects an image signal output from the image signal decoder onto the screen and performs convergence control using a predetermined region of the screen displaced from a visible region of the screen according to a convergence control command; and a main microcomputer which inputs the convergence control command to the convergence control unit when the start signal is input from the image signal decoder, stops the convergence control when a completion signal is input from the convergence control unit, and performs a control operation to continuously display the image signal during the convergence control.
the pro in convergence control circuit only..so better change tat..
We can cet the blue and green adjusted but not the red. It like watching tv in 3D
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
I have red and green lines with a 3d effect on my screen at the bottom
  • Screen looks 3D
The screen is bright with warped faded red, blue and green horizontal lines. It has happened before and it would just go back to normal. Tried automatic convergence - no change. HELP!
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Convergance the green is all over the place!!
  • Screen looks 3D
Red, green, and blue lines at bottom of screen, mirror looking effect, also looks like 3D. Got at a garage sale so no manual.
  • Screen looks 3D
The picture looks 3D
  • Screen looks 3D
Convergence
you need to replace both convergence ICs they are STK392-110 you can get replacements at the following link with free installation instructions so you can do the repair yourself.
http://servicemanuals.vstore.ca/
4answers
Pioneer sd-643hd5 rear projection 64" tv has green geometry grid problems
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
