Canon EOS Rebel XS 35mm SLR Camera Logo
Posted on Feb 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shutter speed and apiture priority
What are the settings for both shutter speed and apiture priority on a Cannon EOS Rebel XS film camera.
Anonymous
Level 3:
  • Master 667 Answers
  • Posted on Feb 14, 2008
Anonymous
Master
Level 3:
Answers
667
Questions
0
Helped
221559
Points
1593
The green rectangle is full automatic. You can use the P mode for the same function. In the P mode, you can change settings, in the green rectangle, you cannot.
How to set my cannon eos rebel xs to fast shutter speed
The max Shutter speed is 1/4000 to select this put the camera in Tv mode i.e. Timed value or shutter priority
tip
Canon Rebel XS Firmware Update MAC Models: Canon EOS Rebel XS / Canon EOS 1000D...
Solves: BUSY Error & Error 99
Doesyour Canon EOS Rebel XS / Canon EOS 1000D suffer from either of thefollowing error messages that prevent it from normal operation?
  1. Some cameras may exhibit a phenomenon in which theLCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. Themessage, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears onthe camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from theactual language setting.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems.
To download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware upgrade, click here.
I hope that helps.
__________________________
Follow this link to download the Windows version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
Follow this link to download a pdf version of the firmware installation instruction guide.
Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I'm using a Canon EOS Rebel X S 35mm SLR What setting should i set my camera for a manual shutter speed?
If your camera is a Rebel XS you should have a dial on the top right with a series of letters and icons. To set your camera so you manually control the shutter speed turn this dial too "TV" (Time Value). This setting will allow you to select the shutter speed and the aperture will open or close to achieve the correct exposure. The "M" is (Manual) where you would select both the shutter speed and aperture "AV" is (Aperture Value) where the user selects the aperture they want and the shutter speed increases or decreases to obtain a proper exposure. The "P" (Program) mode allows the camera to automatically select the shutter speed and aperture
Canon Rebel XS has stopped recording images...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS .
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
How to take action shots with the canon rebel xs
There is an action shot setting on the wheel on the top of the camera. If you want to manually control the camera:
-Raise ISO -Select Tv mode (shutter priority mode) -Select a fast shutter speed -Manual focus on what you want to take -Take multiple pictures so one will be good
Cannon 35mm EOS Rebel X S Shutter Problem
problem in shutter clean the shutter with white petrol dry it no need of lubrecant
View finder displays "busy" and the shutter is half open
I can help you fix the BUSY Error or Error 99 of your Canon EOS Digital Rebel XS.
Installation of this Canon EOS Digital Rebel XS firmware version 1.06 update will solve these problems:
I hope that helps.
2answers
New Camera, no picture on screen
This is normal for this camera. Think about it. The CMOS chip can't see through the mirror. After the shot is taken the electronic shutter exposes the CMOS chip and makes an image just like exposing film on a film type camera. Once you get used to it you may like it better. In outdoor or bright light situations it's difficult to view the LCD screen to frame the shot anyway.
My Cannon Rebel EOS 35mm film Camera is producing blank Film
If you are getting some photos where only part of the image is visible, then I suspect that they were photos where you used a flash.
Cameras have a specified maximum shutter speed for use with a flash, this is called its 'sync speed'. This is the fastest speed that the camera will need to open the lead shutter and close the trailing shutter in order to expose the entire surface area of the image and have it evenly lit by the flash unit. If you shoot too fast of a speed, then the shutter will only be partly completed its exposure and you'll get a photo with only part of the image showing. The faster the speed past the sync speed, the less the resulting area of the image. Most cameras will have a sync speed of 1/250 or less. I think a lot of the Rebel models are 1/90 - consult your manual.
Top Canon Photography Experts
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Canon Photography Expert? Answer questions, earn points and help others
