It generally depends on how thick the bar is. If it is directly in the center, it is possible that your Time Control/LCD Control board needs to be replaced.
However, there is a chance that the TCON/Control board alone will not fix the issue, and you will need to replace the LCD Panel.
Depending on your initial cost, the presence of a warranty--extended or otherwise--and your willingness to get it repaired, you may want to consider another set.
Expect to pay around $200-300.00 in labor costs to put an LCD panel in, and the cost of the panel can be quite exorbitant.
