Dryers Logo
Posted on Jan 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My maytag atlantis dryer will constantly run without heat. Also when you open the dryer door the light does not come on. Any ideas of what the issue is?
  • Anonymous May 11, 2010
    the heat sensor may be bad. in newer dryers there is a heat sensor by the element. They do this as a safety now 1 so you dont melt plastics and 2 to prevent clothing from wrinkling. it will get hot and cool down and get hot and cool down....
BOYNISMO
Level 2:
  • Expert 120 Answers
  • Posted on Jan 24, 2010
BOYNISMO
Expert
Level 2:
Answers
120
Questions
0
Helped
34344
Points
264
IF IT RUNS WITHOUT HEAT ALL THE TIME, YOU NEED TO CHECK THE THERMAL FUSE OR IGNITOR. IF IT'S GET WARM SOMETIMES AND TAKES A LONG TIME TO DRY YOUR CLOTHES, CHECK YOUR VENT TO THE OUTSIDE, RADIANT SENSOR, AND COILS
Wont heat and light is out
Dryers either heat or they don't. If you have heat but clothes take a long time to dry, it will always be an issue with your venting system. That could be anything from a clog in the hose or at the outside exit, a smashed vent hose or a very long run of hose which will cut down on effective evacuation of the moist air, to name a few.
Gas dryer wont light with door closed
Check the exhaust to make sure that it is not clogged.
When door is open during drying cycle, dryer continues to heat up.
no,it sounds like the heating element is touching metal and as long as the timer is sending power until it goes to off it will keep heating.change out the element
Maytag dryer wont turn on i hit the push button and nothing happens i have light on in drum when i open the door any ideas of what it can be
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
The heating element stays on if the door is opened,goes off if timer knob is pushed in,but well go of after the cycle has finished
does the dryer still run when you open the door?if so check the door switch,push it in and out a few times to see if the dryer will shut down,sounds like a bad door switch
Maytag atlantis dryer does not heat
Perhaps the thermal fuse is open. All thermostats and thermal fuses should be closed for continuity at room temperature on this dryer.
Go here for more Maytag Atlantis Dryer repair help: http://www.repairclinic.com/0047_8.asp
www.RepairClinic.com
3answers
Maytag Atlantis MDE6200AYW will run, but no heat
Check to make sure that you have the proper voltage running to the dryer first. Next you may have a problem with your heating element or with your thermal fuse. Get your dryer opened up so you can see your heating element. Run the dryer and if you see the heating element come on and then turn right back off again then you have a bad thermal fuse. If it doesn't come on at all though then the heating element is bad. Both parts can be picked up at your local appliance repair shop. Just make sure to unplug the dryer before replacing the part. If you have any other questions let me know and let me know if this was helpful for you. Good luck.
Doesn't heat and dryer light no longer works
make sure you have power to BOTH legs of the 220v.
Maytag Atlantis dryer
Unfortunately the motor now needs to be replaced. New motors cost around $125-$150 and are fairly tricky to install.
Top Dryers Experts
john h
