Coleman 2 Burner Dual Fuel 424-700G Grill Logo
Posted on Jan 24, 2010
Fuel leak I have replaced the generator, but now have fuel leak where tube tube screws into valve assembly
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
288
Points
Have you tried to tighten the generator onto the valve assembly using pliers? This worked for me.
How do you change the flame sensor
It is not a flame sensor. It is a pilot generator or sometimes it is called a thermal pile or thermocouple.
easy to replace...
loosen brass nut, with aluminum tube at gas valve, and take good notice here... Two wires follow along the tubing and are connected to two of three screws on top of gas valve - loosen and remove. then unsecure pilot assembly from under the burner tray. Pull out the pilot assembly as one unit along with the tubing.
Then either unscrew small retaining nut or just pull straight down and generator will slide out.
i would replace the whole pilot assembly. If not at least clean the pilot orifice!
look at the picture at the following site. Click on 'enlarge picture'
good luck.
Parts4heating com Teledyne Laars R0027600 Pool Heater Universal Pilot...
Code PO442
Trouble Code: P0442
EVAP Control System Small Leak Detected
Possible Causes:
Aftermarket EVAP parts that do not conform to specificationsCV solenoid stays partially open when commanded to closeEVAP component seals leaking (i.e., leaks in the Purge valve, fuel vapor control valve tube assembly or fuel vapor vent valve)Fuel filler cap damaged, cross-threaded or loosely installedLoose fuel vapor hose/tube connections to EVAP componentsSmall holes or cuts in fuel vapor hoses or EVAP canister tubes
Magnetic Valve Assembly Part Number: BES820XL/198 leaks
Step 1: Unscrew back cover (4 torx screws and 2 phillips screws) and remove.
Step 2: Slide top warmer forward (may have to force with palm of your hand) disconnect ground wire.
Step 3: Remove valve assembly. While standing at rear of machine it is located in the rear upper left corner (on a 830xl), remove 2 phillips screws and disconnect wires taking note where they are connected. Remove split castanets from conecting tubes (push on one side then slide them off) making sure to also remove grommets.
Step 4: Instal new safty valve assembly reconect all disconected tubes with excisting grommets and reconnect all wires.
Step 5: Remount assembly with screws, reconnect wire to warmer top, slid backward into place and replace back cover with screws, connect to power, fill water tank and turn on.
2answers
I have a Coleman 228F model lantern. When I go to light it, it barely produces any gas. I have made sure it is pumped adequetly and full of new fuel. I can hear gas coming out very faintly and sometimes...
It's likely that it was left away with fuel in it. This causes gel to form which blocks the fuel getting through. The blockage could be anywhere between the tank and the mantles. The order I would check in are;
  1. The feed tube assembly
  2. The generator
  3. The Burner
It's possible to get these parts from coleman or coleman suppliers. To find which needs replacing you'd need access to another similar lantern and try replacing one at a time. Otherwise it's going to be trial and error or just replace all.
There's a manual which shows the assembly and the order number for parts at http://www.coleman.com/coleman/images/pdf/220f_228F.pdf
I hope this is of some help.
1helpful
I Have a 87 corvette that drops fuel pressure if left unstarted for more than a day or two.
Fuel Pressure Regulator REMOVAL & INSTALLATION 5.7L (VIN 8) Engine NOTE: The pressure regulator and base are factory adjusted and serviced as a complete assembly only. Do not try to remove the regulator cover. 1985-88 VEHICLES
  1. Disconnect the negative battery cable.
  2. Properly relieve the fuel system pressure.
  3. Remove the fuel rail from the vehicle, as outlined earlier in this section.
  4. Remove the front crossover tube retaining attaching screw and crossover tube retainer from the right hand rail side.
  5. Unfasten the retainer-to-base screw assembly and rear crossover tube retaining from the pressure regulator and base assembly.
  6. Separate the left hand fuel rail and plug assembly from the right hand fuel rail and plug assembly.
  7. Remove the bracket-to-rail attaching screw, 2 bracket-to-base screws and the regulator and base bracket.
  8. Unfasten the screw that attaches the fuel outlet tube to the right hand rail.
  9. Remove the base-to-right hand rail assembly. Fig. 1: Typical fuel pressure regulator assembly - 5.7L (VIN 8) engine 91035g26.gif
  10. Twist the regulator and base assembly to the remove it from the fuel outlet tube.
  11. Unplug the base-to-rail connector.
  12. Remove and discard the O-ring seals from the following components, noting the location and sizes of the O-rings to ensure proper placement during installation:
    • Connector
    • Fuel outlet tube
    • Rear crossover tube
    • Front crossover tube
  13. Check the O-rings and sealing surfaces for damage that may prevent proper sealing.
  14. Installation is the reverse of the removal procedure. Tighten the retaining screws to 44 inch lbs. (5 Nm).
  15. Connect the negative battery cable, then turn the ignition to the ON position and check for fuel leaks.
2helpful
Obd-2 code p1455
DTC P1455 - Substantial Leak or Blockage in Evaporative Emission Control System
The PCM monitors the complete EVAP control system for no purge flow, the presence of a large fuel vapor leak or multiple small fuel vapor leaks. The system failure occurs when no purge flow (attributed to fuel vapor blockages or restrictions), a large fuel vapor leak or multiple fuel vapor leaks are detected by the EVAP running loss monitor test with the engine running (but not at idle).
Check this possible causes:
After-market EVAP hardware (such as fuel filler cap) non-conforming to required specifications
Disconnected or cracked fuel EVAP canister tube, EVAP canister purge outlet tube or EVAP return tube
EVAP canister purge valve stuck closed
Damaged EVAP canister
Damaged or missing fuel filler cap
Insufficient fuel filler cap installation
Loose fuel vapor hose/tube connections to EVAP system components
Blockages or restrictions in fuel vapor hoses/tubes (items also listed under disconnections or cracks)
Fuel vapor control valve tube assembly or fuel vapor vent valve assembly blocked
Canister vent (CV) solenoid stuck open
Mechanically inoperative fuel tank pressure (FTP) sensor
Check for audible vacuum noise or significant fuel odor in the engine compartment or near the EVAP canister and fuel tank
Tell us news.
4helpful
2answers
What is he code 455 for a 2006 hyundai sonata means
CODE PO455 EVAPORATIVE EMISSION SYSTEM LARGE LEAK DETECTED.POSSIBLE CAUSES CANISTER VENT SOLENOID MAY BE STUCK IN OPEN POSITION / EVAP CANISTER TUBE EVAP CANISTER PURGE OUTLET TUBE OR EVAP RETURN TUBE DISCONNECTED OR CRACKED OR CANISTER IS DAMAGED / EVAP CANISTER PURGE VALVE STUCK CLOSED OR CANISTER DAMAGED / FUEL FILLER CAP MISSING LOOSE NOT TIGHT OR THE WRONG PART / FUEL VAPOR HOSES TUBES BLOCKED OR RESTRICED OR FUEL VAPOR CONTROL VALVE TUBE OR FUEL VAPOR VENT VALVE ASSEMBLY BLOCKED /FUEL TANK PRESSURE SENSOR HAS FAILED MECHANICAL FAULT /FUEL TANK CONTROL VALVE IS CONTAMINATED DAMAGED OR HAS FAILED.
2helpful
My Coleman Generator Model 19G412 has a fuel shut-off screw/valve. It was in the off position. I needed to use the generator, but when I tried to turn the screw/valve to the on position, it would not turn....
explore the possibility of removing & replacing the 'petcock'[fuel valve] in the tank.drain tank,remove gas line,unscrew petcock retaining nut at tank & replace.
7helpful
Check engine light is on for emission evaporator failure-large
P0455 - EVAP Control System Leak Detected (No Purge Flow or Large Leak) The PCM monitors the complete EVAP control system for no purge flow, the presence of a large fuel vapor leak or multiple small fuel vapor leaks. The system failure occurs when no purge flow (attributed to fuel vapor blockages or restrictions), a large fuel vapor leak or multiple fuel vapor leaks are detected by the EVAP running loss monitor test with the engine running (but not at idle).
  • After-market EVAP hardware (such as fuel filler cap) non-conforming to required specifications
  • Disconnected or cracked fuel EVAP canister tube, EVAP canister purge outlet tube or EVAP return tube
  • EVAP canister purge valve stuck closed
  • Damaged EVAP canister
  • Damaged or missing fuel filler cap
  • Insufficient fuel filler cap installation
  • Loose fuel vapor hose/tube connections to EVAP system components
  • Blockages or restrictions in fuel vapor hoses/tubes (items also listed under disconnections or cracks)
  • Fuel vapor control valve tube assembly or fuel vapor vent valve assembly blocked
  • Canister vent (CV) solenoid stuck open
  • Mechanically inoperative fuel tank pressure (FTP) sensor
Check for audible vacuum noise or significant fuel odor in the engine compartment or near the EVAP canister and fuel tank. ----------------------------------------------------------------------------- HX43 DTC P0457: CHECK FOR MISSING OR LEAKING FUEL FILLER CAP
  • Check for missing fuel filler cap.
  • Check for loose fuel filler cap.
  • Check for possible cross-thread fuel filler cap condition.
Is a fault present concerning the proper installation of the fuel filler cap? Yes No REPLACE cross-threaded or damaged fuel filler cap. RECONNECT and TIGHTEN the fuel filler cap only one eighth turn so that the cap initially clicks by sound or touch. CLEAR Continuous Memory DTCs. COMPLETE an Evaporative Emission Running Loss Monitor Repair Verification Drive Cycle (refer to Section 2 , Drive Cycles). RERUN Quick Test . If DTC P0455 or P0457 is present, Go to HX44 . CLEAR Continuous Memory DTCs. COMPLETE an Evaporative Emission Running Loss Monitor Repair Verification Drive Cycle (refer to Section 2 , Drive Cycles). RERUN Quick Test .
For DTC P0455 still present: Go to HX44 .
Otherwise, INFORM the vehicle owner that it is important and necessary to immediately install the fuel filler cap after every refueling event. HX44 DTC P0455: VISUAL INSPECTION FOR SUBSTANTIAL EVAPORATIVE EMISSION SYSTEM LEAKS
  • Check for missing fuel filler cap. If the cap is loose DO NOT DISTURB EVAP system.
  • Verify that both the input port vacuum hose and EVAP return tube are attached to the EVAP canister purge valve. Note: If the EVAP canister-CV solenoid assembly is not accessible during this pinpoint test step, GO to Evaporative Emissions, Section 303-13 in the Workshop Manual for removal and installation instructions.
  • Verify that the CV solenoid is properly seated on the EVAP canister (if possible).
  • Visually inspect for disconnected or cracked fuel vapor hoses/tubes between the intake manifold, the EVAP canister purge valve, the EVAP canister, the fuel vapor vent valve assembly and if applicable the fuel vapor control valve tube assembly.
  • Check for damage to the fuel filler pipe and the fuel tank.
Is a fault indicated? Yes No CONNECT or REPLACE fuel vapor hoses/tubes as required. REPLACE damaged EVAP system components (fuel filler pipe, fuel vapor vent valve assembly, fuel vapor control valve tube assembly, EVAP canister purge valve, FTP sensor and EVAP canister-CV solenoid assembly) as necessary. REFER to Evaporative Emissions, Section 303-13 in the Workshop Manual for removal and installation instructions. GO to HX45 . GO to HX45 . HX45 DTC P1443 and P0455: CHECK FOR EVAPORATIVE EMISSION SYSTEM LEAKS
    Note: When checking for leaks or blockages in the EVAP system, energize (close) the canister vent (CV) solenoid through the scan tool for a maximum of nine minutes per pinpoint test step. Then de-energize the CV solenoid prior to performing the subsequent pinpoint test step. This is done to assure proper closing of the solenoid.
  • Disconnect and plug the EVAP return tube (EVAP canister purge valve to intake manifold) at the intake manifold vacuum source.
  • Connect scan tool.
  • Key on, engine off.
  • Access VPWR PID. If the voltage is not 12 volts or greater, GO to HX61 .
  • Locate evaporative test port [marked EVAPORATIVE SERVICE PORT DO NOT USE UNREGULATED PRESSURE ABOVE 6.89 kPa (1 PSI)] near EVAP canister purge valve or EVAP canister.
  • If vehicle is not equipped with the evaporative test port, GO to HX50 .
  • Install the Rotunda Evaporative Emission System Leak Tester 310-F007 (134-00056) or equivalent at the evaporative test port.
  • Close CV solenoid by accessing Output Test Mode on the scan tool.
  • Select ALL OFF mode and push START button.
  • Regulate the nitrogen or argon gas pressure on the tester to 3.48 kPa (14 in-H 2 O).
  • Follow the instructions that come with the EVAP System Leak Tester and pressurize the EVAP system.
  • Perform the EVAP system leak test.
Does the pressure on the EVAP system stay above 1.99 kPa (8 in-H 2 O) and pass the leak test? Yes No GO to HX46 . REMOVE the EVAP System Leak Tester from the evaporative test port and REINSTALL the test port cap. GO to HX50 .
5helpful
My taurus failed due to code p0442 ecap emiss ctl sys leak detected (small leak)
    Continuous Memory Diagnostic Trouble Code (DTC) P0442 indicates that a fuel vapor leak has been detected [as small as 0.10 cm (0.04 inch)] in the Evaporative Emission (EVAP) system.
    Note: Prior to performing the following diagnosis inspect the Canister Vent Solenoid (CV) for contamination. A situation may exist where contamination holds open the Canister Vent (CV) solenoid enough to set DTC P0442 and also plugs the port to atmosphere enough to keep system from being vented quickly.
    • After market parts and accessories nonconforming to the EVAP system specifications.
    • Damaged, cross threaded or loosely installed fuel filler cap.
    • Small holes or cuts in fuel vapor hoses/tubes (EVAP canister tube, EVAP canister outlet tube or EVAP return tube) in the EVAP system.
    • Loose fuel vapor hose/tube connections to EVAP system components.
    • EVAP system component [EVAP canister purge valve, fuel tank pressure (FTP) sensor, canister vent (CV) solenoid, fuel vapor control valve tube assembly or fuel vapor vent valve assembly] seals leaking.
    • CV solenoid partially open when commanded closed.
    • EVAP canister leaking.
  • Check for presence of fuel filler cap.
  • Visually inspect for cut or loose connections to fuel vapor hoses/tubes in following locations:
    • EVAP canister to EVAP canister purge valve.
    • EVAP canister to fuel vapor vent valve assembly.
    • fuel vapor control valve tube assembly to fuel tank (if applicable).
Top Coleman Grilling Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
