Polk Audio PSW202 Subwoofer Logo
Posted on Jan 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blew a fuse what kind dose it take is it a slow blow fuse or fast blow one,i took out the old fuse and it reads le.3a/250v is it a 3a or .3a
Rob C
Level 3:
  • Master 547 Answers
  • Posted on Jan 24, 2010
Rob C
Master
Level 3:
Answers
547
Questions
Helped
258218
Points
1914
It is a 3A/250V fuse, also known as a 6A/125V fuse.
Power amps generally have slow blow fuses.
If this is helpful, please be sure to hit the "Thumbs-Up" for me!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1699
Points
Wrong ed dantes it's a T2AL250V Glass Fuse.
ed_dantes
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Apr 28, 2010
ed_dantes
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
2335
Points
12
Wrong javaman! its a 2A/250V 5mmx20mm Slow Blow Glass Fuse. i bought 5 in a pack at Radio Shack for 5 bucks, took it home, removed old one, and as a bright white light blinded me and a small smoke trail came off my new fuse, i tried again....same thing, blown, smoke, stench...
Send it to polk 8 bux fed ex, 54 to fix, week later it was on my comfy chair outside the house...Hooked it up, plugged it in, now i got a 7.2 system----SEND IT AWAY, its guaranteed for a year....its been sitting in my closet for 3yrs, now its in the living room corner and sounds good, both of em...but my newer PSW125 blows it out of the water, but together Depth Charges on U-571 BD sound great.
Need to replace pigtail fuse
This may not be a fuse. Bose uses devices like this as "speaker protection". If this device is wired to the woofer, that is exactly what it is. For more information, please visit my website at audioserviceclinic.com. Thank you.
2helpful
Fuse replacement
HI that is a fast blow and more safe circuit breaker.But before replacing it into a bigger value make sure to read the manufacturers recommended value of replacement fuse it is printed right at the PCboard at the place where the fuse is situated...
I have a pair of Technics SL-1200MK@ Turntables and I blew the fuses on the curcuit boards. I'm having trouble finding a discontinued fuse. If you know anyone selling them, please post some links for...
Any decent electrical shop should have those fuses. They tend to come in 20mm and 30mm lengths. You will need to know which. Also there are fast blow and slow blow fuses. If you have the originals and you can see the remains of a coil then you want slow blow. Otherwise just replace them with fast ones. The 1.2 amp fuse can be replaced with a 250 volt fuse.
So you want a 250ma 250v fuse.
and a 1.2A 250v fuse.
How do I know If the fuse that needs replaced is a "slow blow" or "fast acting" fuse?
Look at the stampin on the fuse, if it has TXXA 250V, then it is a slow blow fuse type (T = Time dealy), some may be stamped with SLO-BLO XXA 250V on it.
Post pictures if you are not sure.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
2answers
I currently own a Klipsch promedia 2.1 computor speaker system. However, the fuse blew and i can not find the specific fuse i need anywhere. The web site says that i just need a standard 2A 250V slow blo...
Have you used 2A SLOW BLOW fuse? This type of fuses usually are ceramic type and are very different with the glass type ones. The glass type fuses are (more or less) fast blow. Although the best solution is to find SLOW BLOW fuses like this, in case it's very difficult you can use 3A fast blow fuse also.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
2helpful
265W car charger blew a fuse (while using it on my Harley Sportster!) Some say replace it with 1A some say 3A. The # is LF.T1AH250VP, and by the way, what's up with 250V !!!!!
I would ignore the 250V. The concern is the current. I would not use a fuse higher than the one shipped with the unit. According to the PN you provided it is a 1A (amp) fast blow glass fuse.
Before replacing check the power line to make sure there is no short in it. Also if the cigarette lighter end gets wet it could blow.
Cheers
GPSCity
Fuse
yes, but it must be the same type, slow blow is typical, or fast blow, depending on what was in there originally.
57helpful
PC power supply fuse - T6.3h 250v engraved on end
T = time delay (slow blow)
6.3A = 6.3 Amperes maximum load
H = HRC - high rupture current (as you specified a ceramic fuse)
250V = 250V AC rated
other letters you may see
FF = ultra fast blow
F = fast blow
M = medium blow
TT = very slow blow
L = low blow current
H = high blow current (glass package)
S = sand filled
2answers
Fuses for P-07
the fuse you need is a t4al 250v
this is a common slow blow 250v 4amp fuse.
You can get them at RadioShack
3helpful
5answers
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
k24674
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
