Either the motor is getting blocked.or the motor is got faulty or the motor sensing sensor is got short or moved from its position.in any of this case the ERROR 044 comes up in the unit. so first the motor should be checked with a meter and it should be cleaned manually and little bit oiled internally .,then reconnect the motor and check out.exactlt beside the motor there is a small mini chip circuit board fitted.from that circuit board some wires comes out and goes to the main board.where that wire goes to main board that is a sensor of the board.check out that sensor.if its faulty then that part needs replacement. you Will have to check out this with meter to confirm the exact fault.if there is low current to the motor but no blockage then its time to replace the motor. check out.keep updated.thanks.
Thank you. The microswitch was disconnected.
