On top of the engine you will find a cover that attaches with screws/bolts. Remove those screws and you will find the spark plug wires. BEFORE REMOVING THESE, look to see if oil is on top of or around them. If not, remove oil plug wire at a time by lifting the wire straight up. If you find oil on the spark plug side of the wire, you will need to get a valve cover gasket and replace it along with the spark plug wires, plugs. NOTE: NOTE: NOTE:, YOU CAN NOT LET THIS OIL DRAIN/SEEP INTO THE SPARK PLUG HOLES. Use paper towels to absorb the oil from that area, REMOVE THE VALVE COVER, then remove the spark plugs. Clean the surfaces up, install the valve cover, then the spark plugs, and wires
Get your tools out and learn on the job
