Computers & Internet Logo
Posted on Jan 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The display is very dark. I have reset the
The display is very dark. I have reset the resolution to high and it is still dark
Shadi Abed
Level 2:
New Friend:
  • Expert 72 Answers
  • Posted on Jan 23, 2010
Shadi Abed
Expert
Level 2:
New Friend:
Answers
72
Questions
Helped
25590
Points
164
You are facing ahardware problem may be the leds burnt, you have to send it to workshop to test it
Reset Resolution/Dispaly
when your on your desktop "right" click in the middle of the screen ( away from all shortcuts ) and move down to "properties" or "personalize" and open that,look down the left hand side for "display" you'll see the settings there to adjust resolution etc
2helpful
I set my resolution too high on my VXL Itona C42 thinclient. Now i'm stuck with no display. how do i get it back to normal?
To Reset the display to 640 x 480 press :- CTRL+ALT+SHIFT+F5
To reset the terminal to factory defaults press :- CTRL+ALT+SHIFT+F9
itona, vxl, reset, factory defaults, screen resolution, display
1helpful
2answers
Get a message that says out off range while the green L.E.D. light flashes. then the monitor goes off. any Ideas??
Yes, your computer's video resolution is set too high, an easy way to fix this is by booting your computer in safe mode. you can put your computer in safe mode by pressing f8 continuously while it is booting up. Then you go to control panel>display and change the resolution and pressing apply.
1helpful
Set pixels too high. Now monitor won't display.
Native resolution: 1280 x 1024 @60Hz, That is what you need to set the PC video resolution to. Running XP? Boot up in safe mode (hit F8 while booting up), set the resolution to 640x 480, then reboot into normal mode, reset the resolution to 1280 x 1024 @60Hz.
2answers
I plugged my monitor into another computer i have and the start up screen pops up but then it goes black and says " input not supported"
You need to set the video output of the PC to the native resolution of your monitor: 1440 x 900 @60Hz. You are getting the meaasage because the resolution is too high for the monitor to display.
Heat from monitor
The monitor,screen,adapter or display of a computer is the primary user interface. Monitor problems are some of the most common computer problems since the voltages inside a monitor can be as high as 10 KV. Many of the problems can be fixed yourself by simply changing the settings but in a few cases you may have to either replace or repair the monitor.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); How to troubleshoot and fix computer monitor/display problems
1. The monitor/display flickers
Check the refresh rate. If the refresh rate is 50 Hz/ 60Hz (depending on which country you stay), it can be affected by interference from electrical power signals like those from fluorescent lamps . Increasing the refresh rate to 72Hz is recommended , since higher refresh rates reduce eyestrain and headaches
2. The display works fine initially, then after some time there are black lines on the screen and then the display disappears
There is a problem with the copper windings in the CRT monitor which are getting heated. It is better to replace the monitor
3. For a new monitor, you get a blank screen or distorted image.
Many monitors, especially LCD monitors, can only handle resolutions which are less than the native resolution, so set the resolution at the native resolution only. The native resolution of a LCD display is lower for smaller LCD screen sizes, typically 1024 X 768 for 15" LCD. CRT monitors have a better resolution than LCD displays
4. The display on the monitor is not steady
This is a result of power system interference from users of the power grid, particularly UPS, power tools and heavy machinery. Try changing the position of the monitor.
5. There is a shadow on the images on the display
Try reducing the contrast setting on your monitor.
6. Monitor becomes blank occasionally
Could be a problem with the display card, check with another monitor. The monitor display cord and power cable should be fixed properly and there should be no loose connection.
7. Dark Spots on the Screen.
Move speakers,USB modem and other magnetic devices away from the monitor.
8. Incorrect Colors - red may become dark brown, blue becomes purple.
Check your video cables and connectors for bent or broken pins and wires. Sometimes there may be a problem with your display card, which can be retuned using a software available with monitor technicians.
9. Run Antivirus to scan corrupt software files.Virus cause distorted characters and images.
10. Set your monitor/display pixels to the software requirements. some softwares require higher pixels to run or to be displayed. some media players, web applications, video games applications and photo editors/view softwares have option to view photos on low or high quality
2answers
Showing message out of range
Your monitor settings within windows are set too high for the monitor to display... When computer first boots.. be ready and press the F8 key...
Enter safe mode.. Reset the display properties in control panel to 800 by 600 for a start. Setting the resolution too high past the monitors ability will give you that message.. Most monitors are able to display 1024 by 768 just fine.. Out of range.. means the display settings within windows are out of the monitors range of ability to display the screen resolution you have set... Good luck!!
17" starlogic monitor model M19BNK serial M9B49CKVoo4584
blown capacitors on the vga board or the resolution for the display adapter is set too high for the monitor reduce the resolution in safe mode and you should be ok, if not then the bad capacitors are in need of being repalced
2answers
Resolution is too high
You need to start the computer in VGA mode. To do that, turn on the computer. Keep pressing the F8 key every second until a boot menu appears. Select enable VGA mode. The computer will boot to a 640 x 480 resolution. From there you can go to your graphics properties and select a more suitable resolution for your monitor.
Display
Something's wrong with the Video. That's obvious.
Could be Resolution (too High), Refresh (off), Other Video (TV Out) at time of boot.
Try, removing TV Video, if you're using, so it's not there at time of boot. I've had that problem, I had to break the connection, that means if you want TV Out, you must Shut Down, recconnect and reboot.
I've had problems with the others too, Resolution and Refresh Rate.
Good Luck,
Grand Canyon Tech
Grand Canyon Tech
