Raymarine Smartpilot Autopilot St6002 S1g Hydraulic Inboard Pack Logo
FRAN HEARNE Posted on Jan 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Two circuits thanks for reply we are working on raymarine co. but they say we must go through Porrtsmouth(we are in NZ) The compass hdg is awol, the rest seems okey dokey The prce mentioned was retail sx10, I was told the S1G is out of production, would I contact you directly, for price o? thanks Stuart
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Apr 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
Helped
9248
Points
24
CHECK COMPASS RESISTANCES ,see google CHECK AUTOHELM COMPASS
John Barry
Level 2:
New Friend:
  • Expert 132 Answers
  • Posted on Jan 25, 2010
John Barry
Expert
Level 2:
New Friend:
Answers
132
Questions
0
Helped
49458
Points
164
Does compass read out 000? I have an S1G in stock if you like www.technicalmarine.com 847-746-0100 [email protected]
What's the scoop on the compass placement for raymarine EV1 sensorcore
It replaces the fluxgate compass and adds a few Moore sensors to the system, such as acceleration an deviation sensors to give a m?re intelligent data to the processor
St40 autopilot unreliable.
ou will need professional repair services to work on the fluxgate compass.
Raymarine smartpilot x-5. The fluxgate compass is some 45 - 60 degrees out from the boat compass. I have tried to recalibrate but this does not solve the problem. Any ideas?
First of all - is the boat compass correct? How does it align with COG? Secondly, do you have a magnetic field that interfere with the fluxgate? To test for this you can use the compass on your smartphone or a handheld compass, move about in the boat and keep the phone/compass aligned with the keel. If the heading drifts in the area where you have your fluxgate today, move it.
1helpful
Hi I have a raymarine c120,dose the hiden electronic compass have a reset button,when following a track on screen im am traveling sideways or a stern,,,do I need a new one or reset,??
Do you have the display configured for "heading up"? If it's "north up" then the map orientation will be fixed and your heading will change. Look at the softkeys under "presentation". The C120 doesn't have a hidden electronic compass; it uses the heading from the GPS (which will wander around when you are stopped). If you have a Raymarine autopilot it will provide compass heading to the C120.
Need to reconnect a c-80 system. I think the MFD, radar, GPS, and depthsounder are connected via Seatalk
I think your best bet here would be to post your query on the Raymarine forum.
There are actual technicians over there to look after you.
http://forum.raymarine.com/
Hope this helps you out.
I have a Raymarine ST2000+ tiller pilot. In going to install it, the way my boat is laid out, the best way to install it would result in its being about 5 degrees diagonal to the transom, looking down on...
Hi!
I can't see being 5 degrees off line much of a problem as far as the sweep is concerned.
I'm fairly sure that when you do your 1 1/2 to 2 SLOW circles that the tillerpilot will correct itself to read closer to your actual compass heading as well.
Happy Boating!
I installed a Raymarine compass sensor in a GRP sailing boat underneath the chart table at least 50 cm away from metal and magnets. It is connected to a SP X-5 computer unit and a ST6002 autopilot...
If I were troubleshooting this, I'd manually adjust the orientation of the compass sensor until it matched the true heading. Once that was done, I'd move it side to side to ensure it's changing in the correct directions. If not, the unit could be upside down. Let me know how this turns out.
We have a Raymarine ST8001 autopilot system that we are unable to get throught the calibration mode to set deviation. Our boat dealer mounted the fluxgate compass within 18" of the emgine which was too...
compass needles are affected by iron objects and can also be affected by field magnetism generated by current flowing through a wire .Bilge pumps , winch motors are heavy current drawers and they could affect the compass operation
while the voltage is low the field of the magnetism around the wire can influence the compass heading so check for any electronic apparatus wiring close to the unit ( radio , radar etc
it may be necessary to run the powers wires in an insulated sheath ( like coaxial cable or other insulated power cables) around sensitive equipment
talk with marine equipment installers to get better ideas as to prevent interference with the compass
What is the petrol to oil ratio for the talon chainsaw
Hello Tony;
TalonTools.co.nz
http://www.husqvarnaoutdoorproducts.co.nz/temp_homepage.html
I suspect these are Chinese. Every Chinese saw I have ever encountered recommends 25:1. If you contact Husky and get an answer please post it back here (below). TIA
A second site
http://www.talontools.com.au/html/about_talon.html
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Raymarine C 80 Head up problem
I calibrated my autopilot compass and that resolved the problem. My auto pilot compass was about 100 deg out.
Once i did this the problem was resolved.
Top Raymarine Boating Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
