Panasonic WhisperFit-Lite Low Profile Bathroom Fan with Lights FV-05VFL2 Logo
Posted on Jan 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our new bathroom fan is not clearing the room the ceiling is wet and the paint peeling the fan is model #FV-LP003
Anonymous
Level 2:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Expert 42 Answers
  • Posted on Jan 23, 2010
Anonymous
Expert
Level 2:
Teacher:
Answers
42
Questions
0
Helped
13476
Points
133
I use to be a chimney sweep. One of my jobs was to clean vents for dryers and bath vents. What could be your problem is that you have a bird nest in the vent system. It sounds to me that you have a vent on the roof for the fan. A bird could have damaged the cap to gain entrance and built a nest. With the cap gone, rain can come in. With the nest, it will not vent out the room. You could call your local chimney sweep company and they will clean it for you. Or if you are capable, Lowe's or Home Depot sell dryer vent cleaning rods. They are sturdy but flexible rods with a 4" brush on the end. Two other handy tools will be a high power shop vac to **** out anything from inside the vent, and a high power blower that has vacuum capability to use out side the house. Cafe full though, if it pulls out a nest, it will shoot it out with great force.
3helpful
3answers
How to completely remove oil paint on my ceiling?
clean ceiling and use BIN primer (2 coats). Ceiling peeled from build of moisture, install a vent fan and have it wired to bathroom light. This way if light is on fan is on.
3helpful
4answers
We found that the water was leaking into first floor ceiling from the pipeS of the toilet leading to bathroom wall. Plumber replaced the pipe and we don't see any leaks.
you need to leave if for a few weeks to dry out. or put a heater in room to help dry the dsmp patch, air flow heater. one with a fan.
May 02, 2018 • Home
What could be the cause of the fan not ventilating the room?
Is there a switch to recirculate,or fresh air ??
Paint problems
I am painting my bathroom ceiling and the existing paint is peeling off as I am applying the new paint what do I do ?
Jan 08, 2014 • Garden
How can i prevent my bathroom ceiling paint from peeling off
One of the main reasons for the breakdown of paints in bathrooms, is of course moisture. Do you have a fan/ventilation system, (not just a recycling air filter,) that can be turned on when you bathe or shower? This would help. Also, a better type of finish would be an eggshell or satin finish type paint. The moisture cannot gather to the same extent on this type of finish.
Lately, I found that my wall and floor are wet early in the morning after using the cool breeze evaporative system whole night with maximum speed. Also I have been noticing my paint on the ceiling is...
yes there is kind of one problem im not really sure but i think its because its too cold or something then the room temperature goes up to warm and i think that is why its wetting your place/room
1helpful
Yellow Spots on Bathroom ceiling/walls after showers
You will have to paint over your new paint with a primer called BIN which will dry in about an hour. Then you can put your color coat on that. Problem solved.
Dec 04, 2009 • Home
Retrofitting the Panasonic FV-11VF2 bathroom fan
SHOULD BE NO PROBLEM I HAVE REPLACED A FEW MY SELF. THE PANASONIC IS QUITER BUT THE BROAN IS CHEAPER.
1helpful
3answers
Installation of a Panasonic Fan FV-05VFL2...
If you are not very handy I don't think I'd tackle this project. There's going to be drywall cutting, backing to install, attic crawling, wiring, ducting to attach, proper insulating. As an electrician I've done this sort of thing in between 1 and 2 hours, depending on how smooth things go. If you find somebody you trust that's done it before who is willing do to it on the side for cash you're looking at $25-$60 for labor. Is it worth it to you?
Top Panasonic Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Panasonic Hardware and Accessory Expert? Answer questions, earn points and help others
