Unfortunately this model is not sold here so my advice can only be general advice. Over voltage will normally blow a PCB before the fuse has a chance to blow so you should be investigating that part first before looking for a fuse it may not have. It is only going to be fixed by an appliance repair technician, preferably one authorised by Kitchen Aid. As a rule I would not expect the PCB to be repairable after double over voltage. It is probably going to need for it to be replaced. Now is probably a good time to enquire with your Kitchen Aid repairman to see if conversion to your UK voltage is economic or possible as money is going to have to be spent anyway.
When your mixer is not starting , you could have a motor that has overheated as the mixer motor is thermally protected. An electrical problems such as a reset GFCI outlet or electrical breaker may also be causing the problem.
The manual recommends turning off the mixer and also waiting for about 10 or 15 seconds, and turning it back on. If the mixer still will not run, wait for 30 minutes before trying again. The unit does not have a reset button, so if it still doesn't operate after a 30-minute wait, you'll have to look elsewhere for the problem.
1 (800) 541-6390 for customer service for counter top appliances and kitchen tools and kitchenware.
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
I have no idea, where did you see this?
