2001 Porsche Boxster Logo
Posted on Jan 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My battery is flat and can not get into the boot as the boot release is lock ??
Anonymous
Level 3:
  • Master 510 Answers
  • Posted on Jan 23, 2010
Anonymous
Master
Level 3:
Answers
510
Questions
0
Helped
384355
Points
1812
Remove plastic panel right of acc pedal
You will see fuse panel.Look for red retangular block,not a fuse
Pull out fully,if tight use small screwdriver carefull not to damage fuses
Once pulled out on the top you will see a metal strip
Connect jump leads/booster + to this, connect - earth to door latch on inner door jam
Now press button to release boot/hood.
Where is the shift lock overide release button on 2002 gmc envoy
Page 95 (Section 2-26) refers. It is hidden!
Shift Lock Release This vehicle is equipped with a shift lock release system. If your vehicle has a dead battery and you need to have your vehicle towed, there is a shift lock release lever that will allow you to move the shift lever out of PARK (P). To access the shift lock release lever, do the following:
1. Press on the sides of the boot around the shift lever to release the boot.
2. Lift up the boot on the shift lever and you will see an orange lever.
3. Press the orange lever down and move the shift lever out of PARK (P).
4. Snap the shift lever boot back in place.
https://my.gm.com/content/dam/gmownercenter/gmna/dynamic/manuals/2002/gmc/envoy/2002_gmc_envoy_owners.pdf
2answers
Shift button on a 2002 trailblazer won't engage
Shift Lock Release
of PARK (P).
orange lever.
out of PARK (P).
Mercedes c250 boot
you should be able to use the mechanical key that is located on the side of your remote key fob. It slide out.
Then insert it into the lock under the rear lip of the truck near the release handle.
Hope this helps
Emergency trunk release
Usually, the "T" handle is an emergency release, in case someone becomes locked in the trunk, believe it or not.
It's attached to a cable that activates the latch mechanism.
2001 Mercedes clk230 infrared key wont turn in ignition
a the problme is that the ignition is glued shut. i am a mechanic i see these thing every DAy.
thanks DING!
1helpful
2answers
Flat battery
No, you dont need to break windows. use the mechanical key that is slotted in the end of the normal electronic gizmo key to open the drivers door. It doesn't work on the boot lid even though it should so you need to energise the electric boot release from unde rthe bonnet as described elsewhere in this solution.
3helpful
2answers
Mercedes-Benz 230clk coupe 1998 with dead battery
I had same problem with my 2002 CLK430. Dead battery with car locked. You can't open doors with the mechanical key (inside remote key), as windows need power to slide down slightly to allow clearance, so you can't access the hood release. The answer is to insert the mechanical key in the key hole for the trunk (boot). It will only go in one way, with the slightly larger grip part down. I found it easiest to turn with a pair of flat nosed pliers. Turn counterclockwise to the left to to the 11 o'clock position. Then push the release in and the trunk will open. Battery is located in the right rear quarter under the flooring panel that also covers spare tire. Hook up charger or jumper cables and power will come back on, as will alarm. To disable, just push the unlock button on the remote key. You should be good to go from here!
3helpful
2answers
How to open boot from inside the car( cant seem to find button )
First of all
  • does it have an electric operated boot release button?
If it does , It probably needs adjusting to remove slack tension.
Trouble is its located.....in the boot....AARRRRGGGHH !! LoL
Although I own a V8 Holden Statesman, not a Alfa GTV,
An elec boot release is an elec boot release, Try what I do for mine.
Have someone push down on boot lid & release it , as you keep quickly hitting the button.OR have them sit on it.
Works most of the time for me .
  • IF IT HAS A KEY OPERATED BOOT
If key fails to turn quite enough to open the boot, Or not at all , then the barrel may need lubrication or replacement.
As electric boot release motors only have a small amount of torque & share the same mechanism as the key itself.Therefore a "sticky" lock will eventually result in the loss of cable tension
To Lubricate you lock ...( no pun intended lol )
  1. Dip the your key in some oil .Motor/Baby/Sewing/Tan/Cooking anything like that, just on the area that is inserted into the lock.
And insert into the lock , Remove & repeat over , whilst jiggling the key untill it will open
  • Or Use a spray product such as CRC or WD-50 with the small straw that inserts into nozzle.
If that fails , and you get cannot access the rear of the lock area from inside the boot to manually operate the latch, Then youll need to force it open and replace the barrel itself.
First visit the wreckers/Auto shop and pick one up...dont forget the key...lol
Next Hammer a suitablly sized flat-blade screw driver into the keyslot of the bootlock, take care not to damage the car, but dont be afraid of making the lock itself look reaaal ugly, hammer,twist,wiggle untill its either open or out of the way .
once visible , turn the "square hole" to open your boot and attach the new lock.
After it has
Top Porsche Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Porsche Expert? Answer questions, earn points and help others
