Onkyo TX-SR605 Receiver Logo
Posted on Jan 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the remote control code (for onkyo receiver
I need the remote control code (onkyo receiver sr 605) for a philips BDP 7500 bluray player
Anonymous
Level 3:
  • Master 2,335 Answers
  • Posted on Apr 20, 2010
Anonymous
Master
Level 3:
Answers
2335
Questions
0
Helped
882353
Points
4663
Philips Blu-Ray player codes for Onkyo universal remotes are: 33007, & 33016.
You can download Onkyo universal remote codes with instructions here.
I hope that helps.
2answers
My remote for my Pioneer Elite BDP-95FD died. Is it possible to get a universal one as a replacement?
You most likely can use a universal remote to control this device, you will just have to search for Pioneer bluray player radio codes that you can configure on the universal remote.
How do I hook up my blue tooth headphones to my onkyo SR 605
You cannot rig up a blue tooth headphones to this receiver with out a blue tooth transmitter ( the Onkyo does not have one built in ). If you have a transmitter it can be plugged into the headphone out socket of the Onkyo ( in front ), just remember that it will cut out the sound from all your speakers when you insert the headphone jack . The advantage though with this connection is you can control the headphone volume using the Onkyo remote.
2answers
Need Onkyo SR803 Remote code for Samsung BD-P1590
This should help you.
http://codesforuniversalremotes.com/samsung-blu-ray-player-remote-control-codes/
2helpful
2answers
Bdp s350 sony bluray player.
I would just like to add that I have a Sony BDP-S500 player and a Sony TV.
The Sony TV's remote was preprogrammed to control the Bluray player, which i discovered by accident, so I didn't have to mess with universal remote control codes or anything.
Hope that helps.
2answers
Need remote control code for a sony BDP S350 blu ray player
you could try getting in touch with the manufacturers of the receiver,or if you have a code in its manual for a sony dvd,you could try that as that all blueray is,it might not matter about model of dvd.
2answers
Onkyo sr 605
Check with and download the firmware update from the Onkyo web site.
2answers
Code for Sony BDP-S300 Blu-ray player on Onkyo remote
Player can be made to work without remote. But it is a pain.
You need to press pause then play in the right combination.and you can get both DVDs and Blu Ray disks to work. I bought a store floor model that did not have a remote. I went through the same problem when I would lose the remote for the HD-DVD player. My four year old daughter knows this trick pause pause play for DVDs and pause play pause play for blu
Onkyo tx sr 605
well most dvd aint 7.1 are using dolby digital cable in digital mode ect on sterio set output on ps3 audio setting to digital
17helpful
10answers
Code for Verizon FIOS remote Control
I have a solution which has worked well for me. It uses the DVD button at the top of the remote. It was a trade-off as none of the codes in the RC144 Philips remote will work any Blu-ray players, so the DVD button was unassigned. The 922, 955 and 977 codes are explained in the directions for the FIOS remote. http://onlinehelp.verizon.net/consumer/bin/pdf/philips%20rc1445302%20user%20guide.pdf
1. Set up your TV button to work your TV.
2. Set up your Onkyo code, pick one to turn on the receiver. I used 3719
3. Use the 9-2-2 code to cycle through all available codes. At about a count of 300 I found one which will turn the Onkyo receiver off. Make sure you start this process with the ONKYO receiver already on. Once you find it press the OK button.
4. Use the 9-7-7 code to power all devices TV, AUX and DVD from the power button.
In this way, each time the power button is pressed it will send both the power on and power off signal to the ONKYO receiver.
This technique works well when you point the remote at the ONKYO receiver and press power button. Apparently the TV has better reception for the signal then the ONKYO does.
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
