Dell Inspiron 1525 Laptop Logo
Posted on Jan 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are the function keys to turn the wireless
Anonymous
Level 2:
  • Expert 218 Answers
  • Posted on Jan 23, 2010
Anonymous
Expert
Level 2:
Answers
218
Questions
Helped
62199
Points
610
It is a wireless switch at the right hand side front. However try Fn +F2 . some dell laptops like Lattitude has Fn=F2 assigned to turn the wireless on.
Anonymous
Level 3:
  • Master 763 Answers
Anonymous
Master
Level 3:
Answers
763
Questions
0
Helped
443814
Points
2622
Press the FN and F2 keys together
How do I turn on wireless capability
To enable or disable wireless functions, you must use the Hot Key combination of "Fn" + "F8". This means to press and hold the "Fn" key (near the windows key), and the press the "F8". This is a toggling function. Each time you press the key, it will turn on or turn off the function. Look for the Wireless Light to ensure that the wireless activated.
How to turn on wireless on Acer Aspire 4520 laptop
Look for a switch for the wireless or a function key that has the wireless icon, the function keys are usually labeled F1,F2, etc and they have icons on top of them, to activate the wireless one, just press ALT and the key together, you should see the wireless light come on.
Wireless turned off How do I turn it on?
You have your wireless connection on the computer turned off. This can be turned off in two ways and normally seen with the wireless light showing the state. On this laptop it is turned on by using Fn + F2 will turn on/off the wireless. The Fn is the function key coloured the same as the secondary icons on your function keys, these are pushed at the same time or hold down the function key and then push the F2 key. This is what it means by switching it on or off.
Wireless capability won't turn on
Make sure you Press and Hold the FN function key then hit the F2 key.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
Some laptops might have a wireless button instead of a wireless switch located above the keyboard or on the front or sides.
How to turn on wifi? Its been 2 -3 days wifi isnot being loaded?
Press and Hold the FN function key then hit F2 while holding the FN Key down.
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
2answers
Hw to on wireless network key
Hi:
Check the Bios setup options and make sure wireless LAN adapter is enabled or don't disabled.
1helpful
How to activate wireless connection without FUNCTION key on lapto
The wireless button is required.there is no option in the softwares to turn on wireless.
What is the function key used to reset/turn the wireless on; the wireless light is on, but my wife's computer keeps telling her to turn on wireless capability and WLAN disabled. We use a wireless router (I...
tHE COMBINATION IS THE FUNCTION KEY AND THE F2 BUTTON TO TURN OFF AND ON THE WIRELESS. HOLD DOWN THE FUNCTION KEY WHILE PRESSING THE F2 KEY... HOPE THIS HELPS
Turn on wireless with function key hp laptop
see if there is a wireless switch on the side/front of the laptop.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
