With BIG wires from battery to cap and then to your amp.
Good idea to put fuse or fusible link between bat + and the cap. Protects against fires.
If one wanted to be safe from starter motor transients I would gate the + power lead with a power relay between the battery and the cap. This relay should close when you are in run or accessory position of your key switch. I recommend this as there are so MANY dead car audio amps. Just search for them on here! A bunch of them MIGHT be caused by inductive transients during starter motor shutdown. Note the inductance is in the grounding wire from teh battery to the engine/chassis.
