Question about Uniden Cordless Phone
Changing the number of rings to answer on our Model 28112 GE Cordless phone
I have attempted to change the rings but I believe the instructions talk about changing the number of rings on the answering machine only and we do not use the answering machine that came with our set. Right now it only rings 3 rings before it goes to our Voicemail--I would like to have it ring 5 or 6 rings. How can I make this happen?
  • 6 more comments
  • Anonymous Apr 28, 2008
    After 3 rings the call goes to my physical answering machine. I want to change this to 6 rings. What do I do
  • barber52 May 28, 2008
    My phone currently rings 3 times before it goes to the phone answering machine. I would like to change to have it ring 6 times. I had a voicemail feature with my local phone provider, but have since had it disabled. Thanks for any help you can give me.
  • Anonymous Mar 17, 2014
    at times, not always, our cordless phone displays "no service", not "no line". The phone is ringing but can't answer it. Changing the the base to another outlet corrects it. What's wrong?
  • Anonymous Mar 24, 2014
    i have trouble with the ring tones, as they are too short only rings 3 times before the answering machine comes on
  • Anonymous Mar 27, 2014
    my dad has this phone and it stopped ringing. I need to trouble shoot from a distance. Any help?
  • Anonymous Mar 28, 2014
    How do we change the no. of rings before it goes to voicemail.
  • Anonymous Mar 29, 2014
    Samsung galaxy phone it only rings twice before it goes to the answering machine how do I make it ring longer before it picks up
  • Anonymous Mar 30, 2014
    Have a KX TG6591C telephone. Need to change the answering rings from 4 to 7.
    Scholar:
  • 84 Answers
The voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
Posted on Feb 14, 2008
SOURCE:
Change number of rings on a vtech cordless phone system CS6719-16
The CS6719-16 isn't an answering machine. Please give us the make and model of the answering machine on which you'd like to change the number of rings.
Apr 08, 2014 | Vtech CS6719-16 Cordless Phone with Caller...
My phone goes to voicemail after 3 rings. how do i change that to 5 rings?
do you have the phone with an answering machine like:
http://www.generalmanual.com/Telephones/GE-25932EE1-Cordless-5-8GHz-Edge-Phone.htm
Or are you using a voice mail system on your phone line? If so, contact the voicemail company or your phone company for information on how to change the number of rings before the forward.
EJ Kudelka
Apr 29, 2011 | GE 25932 Cordless Phone
I would like to increase the number of rings. It currently rings 4 times. Is it possible to change the number of rings
The 25839 isn't an answering machine. If you have a separate answering machine connected to your phone line, consult its documentation. If you subscribe to a voicemail system offered by your phone company, contact them for instructions.
Mar 22, 2011 | GE 25839GE3 Cordless Phone
I want to change the nombers of the rings to get start the answering machin
These are the instructions from the manual, which I found here:
http://safemanuals.com/user-guide-instructions-owner-manual/GE/21028GE3-A-_E
RING SELECT (FOR ANSWERING MACHINE)
This feature lets you select the number of times you want to phone to ring
before the answering system answers a call.
1. Make sure your phone is OFF (not in talk mode).
2. Press the MUTE/PROG button to go to the main menu.
3. Press CID/VOL (up or down) button to scroll to HANDSET SETUP.
4. Press MUTE/PROG button to confirm.
5. Press the CID/VOL (up or down) button to scroll to the RING SELECT menu.
6. Press MUTE/PROG button to enter the menu. RING SELECT 3 4 5 6 TS shows in the display.
7. Use the CID/VOL (up or down) button to scroll to the your selection. The default setting is 5.
8. Press the MUTE/PROG button to confirm. You will hear a confirmation tone and the new setting shows in the display.
NOTE: If you select Toll Saver (TS) the unit answers after the 3rd ring if there
are NEW messages, OR the unit answers after the 5th ring if there are NO new
messages. This allows user to access their answerer from another location and
then hang up after 4 rings to save long distance charges.
Oct 13, 2010 | GE 21028GE3 Cordless Phone
Can I use cordless phone answering machine even if I have voicema
You do not have to cancel the phone company voice mail service. You need to change the number of rings the phone uses to answer the voice mail.
For example, if the telephone company voice mail answers if 4 rings, set the telephone answering machine to answer in 3 rings or less.
Good luck.
joequevedo@charter.net
Mar 03, 2009 | GE 27992GE5 Cordless Phone
Memory names with more than 20 numbers to dial
You can do chain dialing, it is in the manual! If you dont have the manual, here it is!
http://www.home-electronics.net/ge/pc/IB/28112EE1_IB.pdf
Jul 04, 2008 | GE 28112 Trio Cordless Phone
Ge cordless Model 28112 6.0
I found out that I needed to puch the program button. the manual was not clear on this.
Thanks
Apr 02, 2008 | Lands Phones
Setting the number of rings to answer
Press "Mute" to setup handset, select "Ring to answer", here are 1,2,3,5,6,L choice. you can change to 3.
Dec 16, 2007 | GE 28112EE2 Cordless Phone
GE dECT 6.0 Cordless Model 28112 Series
On the base is a button next to the GE logo that says "Do Not Disturb". Pushing that button will enable and disable that feature
Dec 08, 2007 | GE 28112EE2 Cordless Phone
Uniden Cordless Phone Logo
1,961 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
