Maytag MHWZ600TB Front Load Washer Logo
Posted on Jan 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag epic z won't start, except on spin only
My maytag epic z front load washer will only run in the spin only cycle. when i select any other cycle and press start, it shuts off. Help! Repairman can't/won't come for a week!
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Jan 23, 2010
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3734609
Points
36074
First check any filters or screens and drain hoses. Check that the water inlet valves are opening to allow water to come in. Check pump to make sure the propellers aren't broken and it's not leaking. Do you get any error codes on the display?
  • grunt67 Feb 02, 2011
    Our washer was doing the same thing. Took the back off found an obviously broken wire. Spliced it back together and bingo all is well.
Maytag Epic Z won't Drain after rinse cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
1helpful
F71
Select POWER/CANCEL twice to cancel the cycle.
Select DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START/PAUSE.
If the problem remains, schedule service.*
1helpful
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
2answers
Maytag Epic Z Washer has object between drum and tub.
I had the same rattling during spin cycle of my Maytag 4000 series front loading washer. Noticed you could gently pull back on the rubber gasket between the tub and where the door seals. There was a quarter resting against the fixed ring the tub spins in. Problem solved. And I have further realized that long hair can build up in this same spot. But if you didn't know to pull back on the gasket you wouldn't see it. Good luck!
2helpful
Washer will not start final spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
1helpful
My new Epic Z is only one month old
sounds to me like there is a short in the wiring or control board i would call the warranty company to come fix it
Maytag washer wont start spin cycle...
INSPECT YOUR PUMP HUMMING NOISE USUALLY PUMP MOTOR ARE PRETTY RELAIBLE
Maytag Epic
the control board has loose solder connections around the relays.
see this
diff model same issue with new boards as they make them all.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
being it is in warranty its too early for you to fix it yourself.
you will have to wait for them to come out and say the parts are on backorder.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
