Haier 45-Pint Dehumidifier Logo
Posted on Jan 22, 2010
I'm searching for an owner's manual for a 45 pint model #DE45EA-L purchased in 2009. Please, advise.........Thanks!
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 22, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
715
Points
9
Try www.LGE.com
then you can sort through to the owners manual, it didnt solve my issue, and it wouldnt let me upload the service manual
I HAVE A RIVA COLD UNIT IT IS WORKING FINE NUT DISPLAYS E2 ERROR COMPRESSOR MODEL CAJ95132
Reset the system read your owner manual section troubleshooting or download from www.retrevo.com or www. manualslib.com
God bless you
1helpful
I have lost my instruction manual and cannot change te temperature and humidity settings. How do you do this?
Here is a link to an Owner's Manual for a Haier 45 pint dehumidifier. Not sure if yours exactly like it or not, as you didn't mention a model number. You can download and print the manual for future reference.
http://www.haieramerica.com/cool-heat-air-quality/dehumidifiers/45-pint-capacity-electronic-control-115-volt-dehumidifier-de45ek-7
Look for the download in the left hand lower left on the page.
Hope this helps and thanks for choosing FixYa.
E2 error
Unfortunately, for whatever reason, Haier does not list the Error Codes and what the problem is, in their Owner's Manuals. To find out what E2 indicates you will have to contact Haier Customer Support
1-877-337-3639. It's very important to have your Model Number handy before you call.
Hope this helps you to get the answer. Thanks for choosing FixYa.
I am looking for owners manual for classic dehumifier, purchased in Canada
If by "Classic", you mean a Santa Fe Classic Dehumidifier, I'll need the correct Model Number to help you.
Please advise ... Thanks
1helpful
2answers
I need the intruction manual for Delonghi dehumidifier model #DE40P.
Here is a link to the Owner's Manual, you're looking for. You can download and print the manual for future reference. Take good care of your model, perform routine maintenance, as required. As it no longer in manufacture. It has been replaced with a 45 pint unit. However, some parts your model are still available, if needed.
http://www.appliancefactoryparts.com/content/pdfs/109280.pdf
Hope this helped you.
1helpful
I just purchased a second-hand LG 45 pint dehumidifier. I need an owner's manual, free if possible........ Thanks
Jenifay, take good care of your dehumidifier and do all the routine maintenance that is recommended in the Owners Manual. As this model has been discontinued.
The following link will take you to LG's Knowledge Base. On the right of the page, you will see Dehumidifier Manual English. Click on that, and you can download and print the manual for a 45 pint LHD4SEL Dehumidifier.
Since I was able to get you a free manual, would you be kind enough to rate my response to you?
Thanks.
3helpful
3answers
Haier 45 Pint Electronic Dehmidifier Error Code E2
Jason, currently the only 45 pint dehumidifier that Haier sell is Model # DE45EK or DE45EK-L or EK-T. If any of those matches the Model Number of yours, you can down load and print the Owners Manual from the link below. However, the model numbers I listed make no reference to Error Code E2. If your Model Number does not correspond to any of those numbers, your unit is probably no longer manufactured or available.
http://www.haieramerica.com/en/asset/product/4ba7175e54
With that said, there are two things you can do. First, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then, plug the unit back in and turn the Master On/Off Switch to ON. Did the Error Code clear itself. If so, set the controls as you normally would.
If that didn't solve the problem you can contact Haier Customer Service at 877-337-3639 and they will advise you what to do, to clear the error code.
Hope this helped you to solve the problem.
3helpful
Looking for a owner manual for a dehumidifier manual
Your owners manual is not currently available online. However, if your contact Customer Support
877-337-3639, they will be able to help you. Make sure you have the exact model number available when you call.
Hd456e need manual
You can get the manual on the link below. just scrool down and type the # code in then click on download.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good Luck and please rate 4 thumbs up for the free answer
Owner's Manual
A dehumidifier takes water out of the air so you don't put water in it. Give me the entire model # from the sticker on the unit and I will see if I can get info on it for you.
Top Haier Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
