Check / replace fuse F9A04 in power supply that provide +24V to convergence out chips in TV.
If fuse blew off again then convergence out chips would be replaced.
Let me know if you have additional question.
Thanks.
Can you give me an idea where the fuse is I have the back off and there are three main boards.
Below exploded view of chassis shows Fuse location in TV, marked section is power supply area.
It would be pico fuse, looks like resistor.
Thanks found it, do I need to look at any other fuses F9A02, F9A05. Where can I get the fuses?
Its up to you to check all fuses there.
Fuse are widely available in Radio Shake or any other part store in your area.
Click HERE or HERE if you want online order.
If the fuse blows after replacement, then the convergence chips are
bad? Which ones and where can I get them? Any advice on replacing them.
The set was made in 2002 do those chip have a short life due to heat.
Thanks
Roger
Yes, if fuse blows again that means convergence out chips are bad and needs to be replaced.
Required STK392-570 (convergence out ICs) are available in Part Store for $24
Following image shows convergence out ICs (marked with blue)
If the fuse blows after replacement, then the convergence chips are bad? Which ones and where can I get them? Any advice on replacing them. The set was made in 2002 do those chip have a short life due to heat.
Thanks
Roger
