Jacuzzi Bath Maxima EL61 959 White elongated two-piece high-perform Logo
Charlie Posted on Jan 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to replace all the parts inside the tank of Jacuzzi toilet
The "universal" parts found in Lowe's or Home Depot do not do it for my Jacuzzi toilet. I believe it is the Maxima model. These parts are very different from a standard toilet. For example, instead of just two holes (one for water coming in and one for water going out), there is a 3rd hole, which appears to be a separate overflow drain. In the universals, the overflow is routed through the hole that the flapper covers. Additionally, there is a plastic tank inside the porcelain tank, which is supposed to hold all the water. I can't find anywhere that sells a complete replacement set of parts.
Stephen Martin
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 14, 2013
Stephen Martin
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1319
Points
I'm looking for the water and flush valve for a jacuzzi toilet, model SWP2959.
Anonymous
Level 3:
  • Master 714 Answers
  • Posted on Jan 26, 2010
Anonymous
Master
Level 3:
Answers
714
Questions
Helped
316500
Points
1893
Had a simular problum.
For about $130 you can have a 1.6 LF new in box and start saving water.
Hope this tip helps.
R/
David
How do I fix a running toilet
replace the guts first,with universal ones,5 bucks at walmart,what happens is calcium builds up inside them and slowly closes the fill hole,just like your shower head,its easy to install the new "guts", Fluidmaster Universal Fill Valve 400ARP25 The Home Depot
install toilet fill unit Bing Videos
Jul 20, 2015 • Home
1helpful
2answers
Where can I find replacement parts?
home depot etc, most hardware stores.
Mar 30, 2012 • Home
8helpful
3answers
Can't find replacement seat for the toilet? Where
You can't be serious? Get yourself down to Loews, Home Depot or Menards and get yourself a seat brother! It's not rocket science or that only Jacuzzi seats fit fit Jacuzzi toilets lets get real, comon lets get er done PAL.
Need parts for a 30 year old jacuzzi toilet
Depending on what the innards look like, you can spend $15 at a home center like Home Depot for a toilet replacement parts kit. They're easy to install (about 30 minutes) and fix most common toilet issues.
If this won't work you might need to contact a plumbing supply company in your area. You'd be surprised what they have in inventory....
I need a tank to bowl gasket kit for jacuzzi toilet 1.6gpf/6lpf
Lowes, or Home Depot carries a variety of these.
Nov 28, 2009 • Home
I am looking to replace the part inside tank that lifts flapper
Remove the entire chain, and take it to a hardware store, or home center (Home depot or Lowes) and ask for a suitable replacement.
Or you could replace the entire flapper that comes with a chain, at any of the above named stores.
Dont forget to take the flapper with you...
Good luck
Top Jacuzzi Home Experts
john h
Gene Lawson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
